Bateleur
Postby Bateleur » Thu Jan 10, 2013 4:09 pm
I hope that GPS is not a PILOT 3. I am now wondering if I put our GPS away last I flew on Sunday??? (**)
Stef Oosthuizen
Step it up a notch!!
ZU DBP
Bateleur
Postby Bateleur » Thu Jan 10, 2013 4:18 pm
Eish, Bundy, It is not our GPS. I phoned Feizel. :P I am sure we will get the owner soon. Thanks Feizel!!!!
Stef Oosthuizen
ZU DBP
Postby Bundy » Thu Jan 10, 2013 4:25 pm
BATELEUR wrote:Eish, Bundy, It is not our GPS. I phoned Feizel. :P I am sure we will get the owner soon. Thanks Feizel!!!!
...I'll cancel your kick in the balls then! :lol:
Would be very difficult for ours to fall off....that bracket is like a vice. (^^)
BeanCounter
Postby BeanCounter » Thu Jan 10, 2013 4:54 pm
mulderpm wrote:A GPS in a prop.. ## ...neither will be functional afterwards (**)
Ditto for a strobe in a prop. I gave my strobe a haircut this way, blew the replacement on the first flight, convinced them to give me a 2nd replacement at no-cost, and now that's packed up as well. So I'm writing off the R1,400 I paid for the $%!$! thing and will look for a different make & model. School fees.
Bundy wrote:What's happenned to that pencil pushing Cobra driver?? Jy's baie stil Jaco...lewe jy nog? ^
Ek werk my blerrie gat af. En die slangetjie is grounded at the moment pending some TLC - I need to clean the air filters (waiting for the K&N kit to arrive), change plugs and I decided to switch out to marine oil so I need to do that too. Maybe I should post this under Technical but you guys will know in any case - the rubber seal where the sensors connect on top of the oil tank is leaking and it's not sold as a spare part. Short of buying a new rotax tank (for the tidy sum of R2,200 (**) ), any ideas how I can fix this? Also, in switching out the oil how pedantic do I have to be not to let marine & chainsaw mix?
ZU - KBP Cobra
Time spent flying is not deducted from one's lifespan
Postby Bundy » Fri Jan 11, 2013 6:38 am
Hey Jaco....so bly jy lewe ^
No need to explain...I'm also working 6 days a week at this stage. :( Too much graft without flying is just kaksleg :evil:
Sorry to hear about the issues on the slangetjie, hope you get it right asap (with minimal damage to the bank balance) I leave the technical advice up to more qualified personel :)
Steve Bosch sent me an sms inviting us again to his runway....seems to be a bit of a challenge to us! He says that the record for trikes arriving at his spot is 8....I am working this weekend but why dont you and the rhino boys try and beat that? He just asks you to let him know how many will be coming so he can have some sammies ready for you. 8)
Steve Oh Eight 2 seven 72 74eight 6
Please call him guys, his hospitality is appreciated.
EDIT: On second thoughts...check the weather guys! :shock:
mulderpm
Postby mulderpm » Fri Jan 11, 2013 4:56 pm
Hi Jaco happy new year. (^^) (^^)
I have some ideas but give me a pm or next time I see you we can talk. Went for my medical today and visited with Fred Blockland afterwards. Reminiscing and talking flying technical... (^^) ..it was great. He was my first instructor. I went through 4. :shock: :shock: Most of them still alive :lol: :lol:
I will be at Springs and Brakpan this weekend for a new years reunion.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
mulderpm
Postby mulderpm » Sun Jan 13, 2013 9:58 am
Had a leaker visit & brekkie with the guys at Springs. Only got away there at 1....unfortunately no flying. :(
Jaco, look at Rotax, Service Instuction, SI-2ST-008, "Suitable operating fluids for Rotax 2-stroke engines...", paragraph, 3. The Note. ##
Paul Mulder
ZU-DBC Aquilla
Pretoria
KlapperKnop
Postby KlapperKnop » Sun Jan 13, 2013 8:02 pm
There are so many debabtes around oil and it just depend with which AP you talk. I have read even on this forum and each oil has its merits. Here is a link (URL) of OILS that were tested on 2 stroke engines; I leave it up to the reader to decide.
http://www.ultralightnews.com/features/oiltest.htm
Another article:
http://www.theultralightplace.com/choosing_oil.htm
Based on the above article it make sense for training schools to use chain saw oil as the engines are continiously in circuit (stop start type throttle) whereas the scenic cabbage patch flyer are rather constant throttle throughout the flight; in this case marine (outboard) oil.
There is also a believe that a 582 runs cooler than a 503; not according to ROTAX.
quote from link above "These 532 and 582 engines run at internal temperatures similar to the air-cooled Rotax engines, as evidenced by their use of the same spark plug."
ZU-DJE
mulderpm
Postby mulderpm » Mon Jan 14, 2013 6:32 am
100% Faiz. (^^)
The debate goes on. In their SI, Rotax specifically excludes Marine 2-Stroke oil. They recommend Castrol 2T, which is a motorcycle oil and is generally available. Maximum combustion temp for a 503 & 582 is 655 deg C. This is significantly hotter than any outboard. ## Rotax also refers to this difference. ##
I also do not believe the choice is extremely critical. I know some pilots who only use marine, others only synthetic, others only Chain Saw others only 2T. If you speak to the guys at the coast they swear by marine for its corrosion inhibiting properties. Inland generally, schools use Chain Saw. vhpy The choice is yours. puff
Paul Mulder
ZU-DBC Aquilla
Pretoria
mulderpm
Postby mulderpm » Mon Jan 14, 2013 7:33 am
The link to the official Rotax Service Instruction, SI-2ST-008.
http://www.flyrotax.com/portaldata/5/dokus/d04362.pdf
Paul Mulder
ZU-DBC Aquilla
Pretoria
mulderpm
Postby mulderpm » Mon Jan 14, 2013 7:38 am
Does anyone know where I can get Slick 50 in Gauteng?
Paul Mulder
ZU-DBC Aquilla
Pretoria
Postby Blue Max » Tue Jan 15, 2013 5:39 pm
8)
My Rotex have 900 hrs on the clock.
I bought it at 320 hrs.
I use any available mineral two stroke oil.
Whether it is mobil, caltex, lawnmower, chainsaw, outboard or what have you..As long as it is two-stroke oil.
Have a nice day. ## ## ##
KlapperKnop
Postby KlapperKnop » Tue Jan 15, 2013 5:49 pm
Thursday's WX looks good for a morning flip. Anyone??
ZU-DJE
Postby Bundy » Tue Jan 15, 2013 5:52 pm
mulderpm wrote:Does anyone know where I can get Slick 50 in Gauteng?
Last time I checked...you were slick and 50 chom! (^^)
Missing you bunch of nutbags....flown buggerall in 2013 so far! :(
Catch you all on the weekend though 8)
mulderpm
Postby mulderpm » Tue Jan 15, 2013 6:02 pm
Hi Paula. missing your place...Elands. :cry: Can we come back?? vhpy
Some Trikes @ ML with 582's have done 1600hrs with the original crank on Super Chainsaw. At Petit, one 503...that I know of....has done 2000 plus....same oil. vhpy Choice is yours. :?: Speak to the AP's to find out how it works...it is not just the oil. vhpy Rotax engines, if looked after properly, go way beyond their TBO before a TBO! vhpy
Sorg vir haar, streel en pamperlang vir haar, en sy sal jou dien vir jaaaare... vhpy Jy moet haar ook gereeld gebruik :lol: Lank staan maak haar moeg. (**) Klink bekend :lol:
See you all Saturday. WX looks K@@@@@K though (**) (**) (**)
Paul Mulder
ZU-DBC Aquilla
Pretoria
