124.4 Freq as per AIP S004/09
- bluesmancoops
new area for 124.4 Freq as per AIP S004/09
Mike Cooper
- bluesmancoops
Re: 124.4 Freq as per AIP S004/09
if you want a better image ... pm me and i can email it to you
Mike Cooper
you mean new area boundaries for FAD200 in Cape Town
Yes,
now Morning Star is not included.
This does mean when you are flying from Morning Star Westwards, you remain on 124.8 instead of changing to 124.4 once you cross the N7. When you cross the extended centreline of FACT, which is basically along the railwayline, you change to 125.8, special rules west.
Yes,
- bluesmancoops
Morph wrote:you mean new area boundaries for FAD200 in Cape Town
Yes,
yip
Mike Cooper
- Wargames
I'd like to know as well!!Morph wrote:What date is it effective?
AIP Supplement is dated "12 February 2009", but does state that it is the new lateral and vertical limits for FAD200 as per supplement dated 25 sept 2008.
Would presume it is active as we speak, uhm write!
- bluesmancoops
looks like 12 Feb 2009Morph wrote:What date is it effective?
Mike Cooper
- bluesmancoops
hey dirk how r things?Wargames wrote:I'd like to know as well!!Morph wrote:What date is it effective?
Mike Cooper
I do have one concern I have forwarded onto CAA
If you look at the attached proposal from CAA you will see the red shaded sector as the new Delta 200. Their extended centreline pracitically disects Morning Star, in fact shows Morning Star to be in Special Rules West. When we extend it using Google it falls more to the West, leaving us in Special rules East, with about 1 mile to the West before having to change frequency to 125.8.
I have emailed them and am waiting for an answer
- Extended centreline.jpg (88.5 KiB) Viewed 1519 times
- FAD 200 Revision - CAA Proposal.jpg (39.71 KiB) Viewed 1519 times
- bluesmancoops
true but this hasn't changed?Morph wrote:I do have one concern I have forwarded onto CAA
Mike Cooper
It now shows Morning Star barely inside the 125.8, and if this is the case a circuit will require various frequency changes between 124.8 and 125.8
Refer to the image
the circuit is depicted in purple
Refer to the image
- Morning Star in special rules west.JPG (53.3 KiB) Viewed 1486 times
- Wargames
Or Procedure change to make morningstar a circuit to the west for 02 and 20 and thus one frequency!!Morph wrote:It now shows Morning Star barely inside the 125.8, and if this is the case a circuit will require various frequency changes between 124.8 and 125.8
We can't,Wargames wrote:Or Procedure change to make morningstar a circuit to the west for 02 and 20 and thus one frequency!!
Our lease agreement with the municipality specifies no circuits to be done over the N7, thus all to the East
- Wargames
Morph wrote:We can't,Wargames wrote:Or Procedure change to make morningstar a circuit to the west for 02 and 20 and thus one frequency!!
- bluesmancoops
Hi Morph - where did u get this map - pls place linkMorph wrote:It now shows Morning Star barely inside the 125.8, and if this is the case a circuit will require various frequency changes between 124.8 and 125.8
Refer to the image
Mike Cooper
