Rotax 582 idle speed
cjkrit
Postby cjkrit » Fri Jul 11, 2008 9:10 pm
What is the correct idle speed for the Rotax 582? [blue top] Mine idles at 1800rpm, but a lot of vibration and shaking and cannot think it to be good for some of the components. How do I make sure that the 2 carbs are set the same? :?: :?:
Wargames
Re: Rotax 582 idle speed
Postby Wargames » Fri Jul 11, 2008 9:13 pm
The rotax operating manual states a idling speed of 2000 - 2200 rpm.
Just check the balancing of your carbs as well. 1800 is high and should not be vibrating so much!!
cjkrit
Postby cjkrit » Fri Jul 11, 2008 9:18 pm
Wargames wrote:Just check the balancing of your carbs as well.
How is the balancing of carbs done?
Postby Duck Rogers » Fri Jul 11, 2008 9:29 pm
Nope...1800 is LOW.
On the Bing carbs the idling circuit essentially operates all the way up to about 3000 rpm.
Set it at around 2200 and she should be happy, but only if your carbs are balanced correctly.
Go here: viewtopic.php?f=13&t=6514&p=63211#p63211
Postby John Boucher » Sun Jul 13, 2008 6:46 pm
2300rpm on my Cheetah and also then the gearbox is quiet and not klunky!
