Trailing edge fluttering help!
Hi everyone, My Aquilla 1 wings trailing edge flutters while flying. We have replaced the bungies and it still flutters only on the right side this is also there on take off. What can we do to repair this?
ZU-EJU
ZU-EJU
Re: Trailing edge fluttering help!
A temporary solution to tighten the trailing edge slightly is by putting a cable tie through the holes where the bungee cords are attached and just tighten them slightly , alternatively send the wing to Solo Wings for a nip and tuck, I had mine done last year and was very happy with the results.
Aquilla II ZU-DJS
Wingfield - 124.8
Wingfield - 124.8
Thanks, i'm on my way to give it a shot
ZU-EJU
ZU-EJU
ZU-EJU
ZU-EJU
- Learning to fly
Hi all....why not change the bungee cords for parachute cord.....look at the imported wings ie Aerossa and Aircreations....aswell as some of the local wings like the Raptor wing....Most use parachute cord or similar cord....Most of the Windlass and Aquilla trikes in the Eastern Cape have gone this route.....works like a dream and you don't have to replace the bungee cords every couple of years..Keep It Simple Stupid (KISS).
This also helps eliminate trailing edge flutter....
- Carel
- Survived first engine out
Please define para chute cord.
