VW Qustions
Bennie Vorster
VW Qustions
Postby Bennie Vorster » Sat Aug 11, 2007 8:42 pm
What is the diffrance between the VW motor with a reduction drive and the one withoute and what is the prop specs normally used with the direct drive motors, the one I'm using with the reduction drive is a 72/52. :roll:
Bennie Vorster
083 277 5110
flykr
Postby flykr » Mon Aug 13, 2007 1:34 pm
Generally direct drives VW's are used for high speed and RD VW's for the slower birds that require better climb performance (longer prop's). Prop's for direct drives generally have a 52" length with pitch ranging from 32-36" for the 1600-1800L, 37-45" for the 2-2.1L and 46-51" for the turbo VW fitted to some KR2's. RPM range for a direct drive VW ranges from 2900 - 3500.
