Please advise me on the effect of attaching a flag (short enough to not touch the prop) to the king post of an trike.
What side effects can be expected and what should we watch out for?
Hanno
Namibia
Attaching a flag to trike
Re: Attaching a flag to trike
Why? The more you add non standard things the greater the chance of it blowing off and going through the prop. Then vibration, then diarrhea, then silence, then more diarrhea, then panic, then mother earth calls you back to her.Hanno wrote:Please advise me on the effect of attaching a flag (short enough to not touch the prop) to the king post of an trike.
Hanno
Namibia
Hanno,
You could probably do it in the same manner as banner towing, provided its professionally done/ installed........ but i re-emphasize- professionally!!!
If you have ever lost a wingtip batton in flight
u will appreciate how much vibration a small piece of flapping material can send right through the entire aircraft
......... serious pucker fibrillations- very bad juju- dont go there!
Side Effects: Crashing;
Watch out for: The green stuff under the plane, stay away from it.
ZU-CPW..... t/bird mk2
Hoedspruit Civil Airfield
Hangar 8
Hangar 8
Hanno my friend
You were a great help when I once tried to import some trike documents from Namibia, referring to the one that the Van Zyl guy and his female student perished with.
I personally would prefer to skip the quips and suggest that you attach the flag to the post and give it the berries. These okes are all just groping. If it does not feel right, abort. You, as an experienced pilot, will know.
If you still feel uncomfortable, contact Oddball, he will give sound advice.
Richard Quinton
Richard Quinton
