I need advice:
Would it be unadvicable to buy a trike with single ignition?
Rotax 503
- Blue Angel
- Survived first engine out
Rotax 503
Single ignition
Hi
I went through this a while ago it doesnt seem to make a difference. The ignition is very basic and robust. Dont let it put you off a plane you like.
Sacha
Sacha
- CHARLIE WHISKEY
- Whats the right frequency?
SINGLE IGN.
MANY MOONS AGO ALL OF US FLEW & KNEW ONLY SINGLE IGN. CHANGE PLUGS EVERY 10 HOURS AND AWAY.. IF YOU LOOK AFTER YOUR ENG NO DIFFS.
CHEERS
CHEERS
Fueled by Faith.
ZS-VMP
ZU-BBR
ZU-CMS
ZS-WFT
ZU-FGR
ZU-CTS
ZS-VMP
ZU-BBR
ZU-CMS
ZS-WFT
ZU-FGR
ZU-CTS
- Duck Rogers
Re: Rotax 503
If it will get your arse in the air, and that's your budget, then go for it. Nothing wrong with a single ignition.Blue Angel wrote:Hi,
I need advice:
Would it be unadvisable to buy a trike with single ignition?
Re: Rotax 503
Found this post in the archives
Did the general feeling regarding 503 SI and DI changed since 2007?
Re: Rotax 503
Nothing changed here just bought a spare 462 with single ignition and never thought twice about dual ignition.
Sacha
Sacha
Re: Rotax 503
Just my comment on this issue. I fly a DI 503 and I detected a difference in power when running on SI or both. On a test that I did the engine did not reach full revolutions (6300 rpm) during SI. I would say there is a definate difference in power output.
Re: Rotax 503
Hi Luther,
Interesting discovery.....I wonder if that is part of the DI design or just a "by Product" due to the design. To do a 1 to 1 (SI to DI) comparison would probably be difficult. Due to the way the engine was ran in the care that was taken with it.
Is there a way of doing an independent test on both engines? Has anyone done it before?
