912's redline @ 5800rpm. Cruise @ 4800-5000. My 912S is fitted with a Warp drive 3 blade prop, cruises @ indicated 95mph @ 4300 rpm. However on full power for take off and climb she only gets to 5200 rpm indicated on the dial
Can this max rpm be because of the pitch of the prop set for cruising or is it more likely an error on the rpm indicator?
