Rotax Autolube bottle Sold
M64_Blaze
Postby M64_Blaze » Sun Nov 08, 2015 11:42 pm
Item: Rotax Autolube bottle
Reason for sale: Not being used
Viewing Location: Cape Town
Price: R450.00
Contact details of owner: marc @ performancedetail.co.za
M64_Blaze
Re: Rotax Autolube bottle
Postby M64_Blaze » Mon Nov 23, 2015 7:30 pm
bump
witwillem
Postby witwillem » Tue Nov 24, 2015 12:34 pm
Is the filler cap pirate of genuine , loooks like a dip bootle cap . ..?john white
Postby nicow » Tue Nov 24, 2015 12:49 pm
witwillem wrote:Is the filler cap pirate of genuine , loooks like a dip bootle cap . ..?john white
Dis 'n genuine pirate...
witwillem
Postby witwillem » Mon Nov 30, 2015 8:32 am
Smaak my Potties nuus se man is op en wakker vandag , pa se slim kind (^^) (^^)
Postby Boet » Tue Dec 01, 2015 3:47 pm
Die genuaan prop is n stuk str....T, Daai plestiek prop is die ENIGSTE prop wat daar werk....soort van. Het baaaie van hulle vervang!! vhpy vhpy
M64_Blaze
Postby M64_Blaze » Sun Dec 06, 2015 10:30 pm
bump
M64_Blaze
Re: Rotax Autolube bottle R450
Postby M64_Blaze » Fri Dec 11, 2015 11:07 pm
Reduced R450
John.com
Postby John.com » Sat Dec 12, 2015 5:13 am
That's a good price, if you need one of these!
Here is the price I paid recently for the CAP only, from Comet:
100874106 Tank Cap Assy R205.06
John Comley
Magaliesberg, South Africa
M64_Blaze
Postby M64_Blaze » Sun Dec 13, 2015 5:31 pm
John.com wrote:That's a good price, if you need one of these!
Just for the cap!?
John.com
Postby John.com » Sun Dec 13, 2015 6:06 pm
Just for the cap!?
Yes, just the cap! :shock:
John Comley
M64_Blaze
Postby M64_Blaze » Mon Dec 14, 2015 1:13 am
Just for the cap!?
Insane!
John.com
Postby John.com » Mon Dec 14, 2015 7:59 am
John.com wrote:
Insane!
Oh, and by the way, that is the SECOND one in a year (see crack on picture below). These caps have a design/manufacturing flaw which allows them to crack between the threaded sleeve and the 'cap' part of the lid if you apply even the slightest pressure when tightening. Anything more than 'LIGHT finger-tight' causes the lid to crack. I complained vehemently to Comet and was told to 'pack my sarmies'; that I had 'over-tightened the lid'! :evil: :evil:
I now fly with the lid on my autolube oil container at a level of tightness which I feel really uncomfortable about!
By the way, the cap in your picture does not look like an original (it may be an older type), which by virtue of the issue raised above, is not a bad thing!
John Comley
Sad-Ham
Postby Sad-Ham » Mon Dec 14, 2015 8:13 am
I found the best way to prevent the cap from cracking is to cut a gasket from thin conveyor belt and place this over the threaded sleeve which then ebables the bottom of the cap to tighten on the gasket and not against the top of the threaded sleeve which causes the crack.
Aquilla II ZU-DJS
Wingfield - 124.8
John.com
Postby John.com » Mon Dec 14, 2015 8:21 am
Sad-Ham wrote:I found the best way to prevent the cap from cracking is to cut a gasket from thin conveyor belt and place this over the threaded sleeve which then ebables the bottom of the cap to tighten on the gasket and not against the top of the threaded sleeve which causes the crack.
Many thanks!
R410.12 worth of advice! vhpy
John Comley
