CH701 Sold
Skyjeep
CH701 Sold
Postby Skyjeep » Thu Dec 18, 2014 9:04 am
SOLD:
Zenith CH701
Factory built 1998 W&P Aviation
722 Hours TT
ATF due 05/2016
Rotax 912UL (80 HP)
3 Blade Warp Drive prop.
90 l fuel capacity
Icom IC-A6
Collins TDR 950 Transponder
Instruments:
Altimeter
ASI
VSI
Turn and slip
Compass
RPM
EGT
Oil Pressure
Oil Temperature
Coolant Temperature
Fuel Pressure
Volts/Amps
Hobbs
Aircraft at Morningstar Airfield, Cape Town
R300k
Contact Wilfrid 0834194937
Zenith CH701, ZU-BKJ
Re: CH701 For Sale
Postby Air Hog » Thu Dec 18, 2014 9:51 am
Hi Wilfrid
Pictures and price very important.
Skyjeep
Re: CH701 For Sale - Reduced price
Postby Skyjeep » Thu Dec 18, 2014 10:33 am
R320k. Still trying to figure out how to upload images... :oops:
Re: CH701 For Sale
Postby John Boucher » Thu Dec 18, 2014 1:29 pm
Photos done.... vhpy
Re: CH701 For Sale
Postby Air Hog » Fri Dec 19, 2014 6:33 am
Hi Wilfrid
Did the Rotax motor have its 15 year overhaul?
Skyjeep
Re: CH701 For Sale
Postby Skyjeep » Mon Jan 12, 2015 4:10 pm
I went away and asked some questions...I will reduce the price to R300k. The 15 year overhaul not done. Although the engine runs like a dream, low fuel consumption, uses no oil, compression tests done on cylinders. Engine hours 698.
rv_six
Re: CH701 For Sale - Price Reduced
Postby rv_six » Mon Jan 12, 2015 5:03 pm
Nice 701, I would grab it at that price but I am having an new Savannah S built now.....
shiny new wings
Postby shiny new wings » Mon Jan 12, 2015 9:17 pm
off the topic, but where in Knysna is this airfield? Is it visitor friendly? Sorry for poaching on your post :)
Skyjeep
Postby Skyjeep » Tue Jan 13, 2015 9:41 am
Probably closer to Rheenendal than Knysna. Very visitor friendly, 600m grass runway, 13/31. Some nice aircraft and nice people there.
Google maps (Knysna -33.950700, 22.979235)
fosterkane
Postby fosterkane » Sat May 02, 2015 9:02 pm
Still for sale?
If so, does this fit in the light sport category?
When was it last flown?
Also, does the transponder have an encoder?
Scott
Skyjeep
Postby Skyjeep » Tue Nov 03, 2015 1:36 pm
Hi Scott,
I haven't been on Microlighters for months. Only saw your message now.
Yes it does fit in LSA
Last flew it 2 weekends ago, 24/10/2015
Transponder does have an encoder.
The aircraft now lives at Morningstar Airfield again.
Wilfrid
Skyjeep
Re: CH701 For Sale - Updated
Postby Skyjeep » Fri May 13, 2016 10:45 am
BUMP
hummer
Postby hummer » Tue May 24, 2016 5:10 pm
Any damage history
Any corrosion
Are you the first owner
flightstick
Re: CH701 For Sale
Postby flightstick » Tue May 24, 2016 8:28 pm
Skyjeep wrote:I went away and asked some questions...I will reduce the price to R300k. The 15 year overhaul not done. Although the engine runs like a dream, low fuel consumption, uses no oil, compression tests done on cylinders. Engine hours 698.
The overhaul is not required unless the aircraft is being used for commercial operations.....( Its on Condition)Don't waste your money and open that motor it will run happily for years to come.
Flooi
Survived first engine out
Postby Flooi » Wed May 25, 2016 5:19 am
This could be a better buy than most aviators realise. YouTube CH701
and see for yourself. New one with 912 ULS and nice panel could set you back
more than R800k... if you are lucky. More than 40 flying in SA. (^^)
