Spinner
Cloud Warrior
Spinner
Postby Cloud Warrior » Thu Jun 22, 2006 10:16 am
Is there any aerodynamic advantage to fitting a spinner to a pusher prop? Or would it just be for looks?
Junkie
Postby Junkie » Thu Jun 22, 2006 10:24 am
Looks Nice is all me thinks..
J.U.N.K.I.E 's
No credit / No returns
Postby Morph » Thu Jun 22, 2006 11:30 am
Yeah, and you can't check your prop bolts during the preflight with one on
Postby RV4ker (RIP) » Thu Jun 22, 2006 11:52 am
Just looks nice. Spinner purely for airflow in tractor application... :wink:
Cloud Warrior
Postby Cloud Warrior » Fri Jun 23, 2006 1:58 am
Thanks for the feedback gentlemen.
Good safety point Morph - I did not think of that. Not worth it just from that aspect. As an aside - what do tractor type prop pilots then do wrt bolt inspection?
P.S. I am busy thinking up "doodah" projects to keep myself busy - am getting bored with just polishing and oiling my mistress.
Postby Morph » Fri Jun 23, 2006 9:25 am
If I had a spinner on I would definitely safety wire the prop bolts as a minimum. Wooden props would worry me because (and this is purely my opinion) as they can go out of balance if not stored horizontally, so can they swell and contract with variations in heat and humidity. Also when you originally torque your prop bolts on, there is an initial compression of the wood. This compression will put whatever moisture in the wood under pressure directly under the pressure point. With time the moisture will displace and the area directly below the pressure points will shrink, causing the bolts to become loose.
If you have a composite prop with a metal hub this is not a problem and torquing the bolts, with safety wiring will be enough
Cali
Postby Cali » Sat Jun 24, 2006 1:14 am
Cloud Warrior wrote:Thanks for the feedback gentlemen.
You should come and visit me sometime. I am about 300km east of you at Southern Cross. Can't miss it just follow the great eastern h/way. The airfield is almost in town. Not much to fly into around here. Away from the h/way there are no powerlines and the fences are normaly in the treelines. The rest is open fields and good enough to land anywhere. I am back online and will give co-ords soon (busy downloading google earth) dont know if there will be good resolution out here. Talk later.
Airborne Edge X
32-4331
"BLUEY"
zu ebl
Postby zu ebl » Fri Mar 21, 2008 8:20 pm
Hi Cloud Warrior
I browsed through the old post and saw this topic,
were could I find a spinner for my Rotax 914 fitted
on my Gyro? If possible please forward me contact
details or anybody on the forum that could assist.
Willie
0824928813
Cloud Warrior
Postby Cloud Warrior » Sat Mar 22, 2008 1:06 am
http://www.cumminsspinners.com/
They are in Oz though but their work is superb.
Solowings Aquilla
32-4817
Massimo
Postby Massimo » Sun Mar 23, 2008 11:23 am
hey Cloud why are you polishing and not flying??
zu ebl
Spinners
Postby zu ebl » Mon Mar 24, 2008 8:20 pm
Hi Guys,
Any Carbonfibre Spinners available, and how's the
suppliers? Saw a few on Gyros - Ela's and MT 03,
Anybody with information.
Cloud Thanks for the info on Crome plated Spinners,
it will look nice, but think delivery will be about 2 - 3 months.
witch size will fit the Rotex 914 UF Turbo?
Willie
Postby Boet » Wed Apr 09, 2008 8:52 pm
0828041896 vhpy
Boer
Postby Boer » Thu Apr 10, 2008 1:25 pm
Massimo wrote:hey Cloud why are you polishing and not flying??
Too many sheep grazing on the airfield? 057
ZS WOA (Meisie Ferguson)
Ploegskaar No. 1
Cloud Warrior
Postby Cloud Warrior » Fri Apr 11, 2008 9:15 am
Guys guys guys - it's the Kiwis that molest sheep - not the Aussies!
Solowings Aquilla
32-4817
Boer
Postby Boer » Fri Apr 11, 2008 9:19 am
The only difference between the Kiwis and the Ozzie's is that the Kiwis do it with gumboots on. Neither know how to play Rugby or Cricket but that's another story.
Ploegskaar No. 1
