Photos Beach Landings
Willie
Postby Willie » Wed Jun 21, 2006 8:48 pm
This is the first time I am posting a photo. So as a test I will show my river and beach landings with a Kitfox in December. East Africa
ZS-APM C182
ZS-UJC Hatz
ZS-VTV Thunderbird MK4
ZU-EJD Thorp T-18
ZS-PPT Tecnam Sierra
ZS-UGS VP2
ZS-UNC KR2
ZS-DMW Tripacer Crashed 1985
Willie
Postby Willie » Wed Jun 21, 2006 8:56 pm
Try again
The Attachment is too big.
Max Size: 100 KB
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
Willie
Postby Willie » Wed Jun 21, 2006 8:57 pm
How do I get it smaller :oops:
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
The Agent
Postby The Agent » Thu Jun 22, 2006 7:05 am
Willie stuur vir my die foto ek sal hom kleiner maak en terug na jou stuur of sommer op sit.
graham@coopers.co.za
Empty Toy Box
Busy Arranging for new toy.
Graham Cooper
Postby Morph » Thu Jun 22, 2006 9:36 am
Willie wrote:How do I get it smaller :oops:
The easiest way to do it is to send it to your self on email. Open the Explorer (right click on Start, select Explore). navigate to the pics you want to post. Select the pics if they are individual pics hold down the CTRL key and click on each pic you want. Right click on the selection, select Send To, Mail Receipient. You will be asked if you want to make the pics smaller. Select Yes.
It will open up your email tool (Outlook or Outlook Express). You will see a blank message, no recipient, or content except for the attachments, all resized. Now just select these, right click and select Copy, go back to Explorer and paste them somewhere else and viola now uyou can use them
Postby RV4ker (RIP) » Thu Jun 22, 2006 11:39 am
Use MS Paint to resize it.
below an example....
Original file is 1.3MB.
Open the pic in MS Paint (Ships free with MS operating systems)
Click on image>Stretch/Skew
Insert % to reduce size. I reduced file of the Demon to 20% and resultant file is 22.8kb :wink:
(This is basically what email prg does)
resize 2.JPG (96.55 KiB) Viewed 2313 times
Willie
Postby Willie » Thu Jun 22, 2006 5:43 pm
Okay now I try again :!:
VLIEG 022 s.JPG (52.05 KiB) Viewed 2280 times
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
GR8-DAD
Postby GR8-DAD » Thu Jun 22, 2006 5:47 pm
(^^) :-(-( =D* );)) =D* baie baie mooi. :wink:
S 32°16'49.8 E 18°53'33.0
Willie
Postby Willie » Thu Jun 22, 2006 5:53 pm
Hoera :!:
VLIEG 021s.JPG (44.24 KiB) Viewed 2273 times
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
Willie
Postby Willie » Thu Jun 22, 2006 6:15 pm
Raai waar is dit :?:
VLIEG 018s.JPG (44.38 KiB) Viewed 2268 times
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
Willie
Postby Willie » Thu Jun 22, 2006 6:19 pm
Okay where do you think this was :?:
VLIEG 024s.JPG (71.41 KiB) Viewed 2264 times
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
Fairy Flycatcher
Postby Fairy Flycatcher » Thu Jun 22, 2006 6:32 pm
Dit lyk wonderlik Willie!
Dis mos wat Microlighting alles oor is :!:
Waar was dit?
Annie
www.comefly.co.za
The Agent
Postby The Agent » Thu Jun 22, 2006 6:57 pm
Lekka Willie net een ding daar is n vuil kol op die lens maak skoon boet.
I think RV4ker shoul have been a teacher.
Empty Toy Box
Graham Cooper
Willie
Postby Willie » Thu Jun 22, 2006 7:19 pm
This was my post on Avcom after the trip in December.
Due to bad weather we landed in the Limpopo river last week on our way to Pomene.
Landing on sandbanks or on the beach can be done safely in the following way with a tail dragger.
Tyre pressure is very important. It must be as flat as possible. Deflate until it wants to show folds. Depending on aircraft size and wait it is about 60kpa.
When you approach the landing area bring the speed down as far as possible and hang the plane on the prop at round out. Be careful not to stall and use flaps on some aircraft. At the last moment, before touchdown, pull the stick back to let the tail wheel onto the sand fist and keep the stick in your belly. Power off. The plane will stop within 50m.
For take off select full flaps and push the stick full foreword. Apply full power and as soon as the tail lifts reduce flaps to best takeoff position between 10 ad 20 degrees and hold the nose just a little higher than normal until the plane lifts off. Keep in ground effect to increase to best clime speed.
Beach landings and takeoffs should be done when the tide change from high to low just before low tide. Land between the water and the high water mark. Pick an area where slope is not too bad.
It is better to land and wait for the weather to clear then to risk flying into clouds.
Happy landings
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
Willie
Postby Willie » Thu Jun 22, 2006 7:22 pm
Agent
Jy het nie die kol in my broek gesien na die landing op Maxixe nie. Die Mosambiekers gee mos nie pad nie :evil:
ZS-APM C182
ZS-UJC Hatz
ZU-EJD Thorp T-18
ZS-UGS VP2
ZS-UNC KR2
