Logbook Entries
mulderpm
Logbook Entries
Postby mulderpm » Fri Mar 01, 2013 12:30 pm
In my Pilots logbook I log my piloting time as the time from the moment the aircraft commences its take-off until the time it completes the next landing (flight). Acording to my instruments, "the moment the aircraft commences its take-off" is defined as when, the engine rpm exceeds 5000 rpm and the airspeed exceeds 30 mph. "The time it completes the next landing" is defined as when the airspeed drops below 30 mph. Some pilots call this wheels-off to wheels-on time or brakes-off to brakes-on time? :-? For instance I wouldn't log any time for taxiing to the holding point, finding a fault and taxiing back to the hangar. :) I also log every flight separately even if it was only for one circuit. I know when you have 1000’s of hours this is not important but what is correct? Also, if you do not have an instrument which calculates this for you how would you log piloting time, HOBBS minus avearge taxiing time e.g. 0.1 hours?
In my Airframe Logbook (aircraft/engine logbook) I log my instruments HOBBS reading as the “total time flown” which is defined as when the engine rpm exceeds 2000 rpm until it drops below 2000 rpm. I know some pilots who log this as their piloting time in their Pilots Logbook? Some define this “time flown” entry, as the time period between the moment the aircraft moves under its own power until it comes to rest at the end of the flight (flight time). Chocks-off to chocks-on time :? However, I do not log the time pushing the aircraft out of the hangar. :lol:
What does RAASA and CAA require and where can I find this definition.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
justin.schoeman
Re: Logbook Entries
Postby justin.schoeman » Fri Mar 01, 2013 1:26 pm
According to Part 61 you must log 'flight time', which is defined as:
“flight time” means –
(a) for the operation of aeroplanes, the total time from the moment an aeroplane first moves
for the purposes of taking off until the moment it finally comes to rest at the end of the
flight;
Note — Flight time as here defined is synonymous with the term “block to block” time or
“chock to chock” time in general usage which is measured from the time an aeroplane
first moves for the purpose of taking off until it finally stops at the end of the flight.
Loco
Re: Logbook Entries
Postby Loco » Fri Mar 01, 2013 1:37 pm
Anthony Hugo
Crosswinds
mulderpm
Re: Logbook Entries
Postby mulderpm » Fri Mar 01, 2013 2:38 pm
justin.schoeman wrote:According to Part 61 you must log 'flight time', which is defined as:
Hi Justin,
Yes, if you take the letter of the wording "flight time" in Part 61, paragraph 61.01.8, "Logging of flight time". But how else would the writer have worded the requirement. The writer could not have said "Logging of flight". For me, "Flight" has a more appropriate definition. It just does not make sense to me to log my flight time as per the definition of the wording. Would you log a flight that was aborted before take off as piloting time in your Pilots Logbook? This has happened to me and I didn't log it. Taxiing does not count as piloting time? :? You can do that without being a pilot.
To prevent confusion I would suggest that the paragraph in Part 61 should refer to the "flight time" definition or define what should be recorded under "flight time" in the Pilots Logbook. :)
Paul Mulder
ZU-DBC Aquilla
Pretoria
justin.schoeman
Re: Logbook Entries
Postby justin.schoeman » Fri Mar 01, 2013 3:05 pm
Hi Justin,
The law doesn't need to be any more specific. Everywhere they use the term 'flight time' they are referring back to the definition. Just like where 61.01.8 refers to 'instrument flight time', they are referring specifically to the definition of 'instrument flight time' in the law.
This is as I was taught by an instructor - when he insisted that I log an aborted flight.
mulderpm
Re: Logbook Entries
Postby mulderpm » Fri Mar 01, 2013 4:51 pm
Thanks Justin for clearing that up.
Paul Mulder
ZU-DBC Aquilla
Pretoria
skybound®
Re: Logbook Entries
Postby skybound® » Mon Mar 04, 2013 9:29 am
mulderpm wrote: Taxiing does not count as piloting time? :? You can do that without being a pilot.
If you read the regs, taxiing is the initial 'maneuvre' that they use to qualify at what stage of operation one does require to have a pilot licence.
Re: Logbook Entries
Postby John Boucher » Mon Mar 04, 2013 8:13 pm
So up to the point where you aircraft has reached 30mph or 5000rpm, who is in control of it and it's systems? You have been under logging your hours :-(
Justin and Roger - SNAP
mulderpm
Re: Logbook Entries
Postby mulderpm » Tue Mar 05, 2013 10:03 am
Stand corrected. Thanks to all.
Paul Mulder
ZU-DBC Aquilla
Pretoria
Re: Logbook Entries
Postby John Boucher » Tue Mar 05, 2013 10:49 am
What would you add per entry after your last entry stamped and filed ?
0.1 or 0.2 seem reasonable? Take the total of your entries and multiply that by the factor and you''ll see how much you have been...... PIC (^^) Not that the hours maketh the pilot vhpy
mulderpm
Re: Logbook Entries
Postby mulderpm » Tue Mar 05, 2013 1:14 pm
100% John. I have about 50 hours logged this way. The others were all done according to flight time. So, as you said, the hours do not maketh the pilot. I am going to leave it and log correctly from now on. For interest sake, I checked through my last months instrument log and the taxiing time, at FABA, is about 5 minutes per flight I.e. "flight time" minus "flight". I.e. about .1 hrs. .1 X 50 = 5 hrs. Not worth it. (^^)
The reason why I started this thread was because I repeatedly noticed confusion. Now it is sorted for all to see. Thanks (^^)
Paul Mulder
ZU-DBC Aquilla
Pretoria
Re: Logbook Entries
Postby John Boucher » Tue Mar 05, 2013 7:55 pm
As long as it is sorted...
Users browsing this forum: No registered users and 27 guests
