Garmin 196 & EasyPlan?
BeanCounter
Postby BeanCounter » Thu Sep 20, 2012 12:24 pm
Hi
I'm struggling to get a Garmin 196 and Easyplan connected. I've basically gone through the list of ports and none of them are working.
Any advice, please?
ZU - KBP Cobra
Time spent flying is not deducted from one's lifespan
JvTonder
Re: Garmin 196 & EasyPlan?
Postby JvTonder » Thu Sep 20, 2012 12:26 pm
I got a 196 and did not know that you could load easyplan, would also be interested to know if it is possible.
Flying feeds the soul!
Postby nicow » Thu Sep 20, 2012 12:40 pm
Ek is ook nou al moeg gesukkel om dit op my GPS te laai.Dit is nie vir my 'n baie gebruiker vriendelike program nie-en dis ook nie goedkoop nie (**) .
Postby Air Hog » Thu Sep 20, 2012 1:17 pm
Ek vind weer Easyplan baie gebruiker vriendelik. Jy kan waypoints na 196 oplaai, net nie routes. So skep jou waypoints op Easyplan, laai op na 196 en skep net jou routes op 196.
Ek sal bietjie by die huis kyk wat my setup is op die 196 en laat weet.
Postby Tailspin » Thu Sep 20, 2012 3:02 pm
Hi All
I must say i have done all of the above to a GPS196.
Route, Waypoints, and all the alternates info everything. (Just battling with the maps)
Your biggest problem is getting the GPS to talk to the computer through the USB port(Basically impossible) BUT i have a docing station that has a Serial port on it. Works like a charm.
Just done the whole NUMBI trip onto my GPS and s023 s023 s023
It is possible trust me. (yes i am in I.T. :oops: )
Rudix
Postby Rudix » Thu Sep 20, 2012 3:39 pm
JvTonder wrote:I got a 196 and did not know that you could load easyplan, would also be interested to know if it is possible.
You cannot load Easyplan onto the 196 (or any Garmin for that matter) but you can transfer waypoints and routes from Easyplan to the GPS. You can get it to work with a RS232 (serial) to USB converter but it is far easier to use a serial port if you can find a PC or laptop with one.
I must say that even though I use Easyplan I find it far easier and quicker to create the route on Mapsource (Garmin's free mapping software) and then transfer it to the Garmin. The whole process only takes seconds. I have a database, in Garmin/Mapsource format, that covers most runways in South Africa, more than 900 of them that can be loaded into Mapsource and use for routing or uploading. I use Easyplan primary to get runway and frequency info that you cannot get from Mapsource. For longer trips I print out the Easyplan "summary" and use it during the flight.
Once I have completed the flight it is quick to download the track from the gps into Mapsource and display it there or with one click in Google Earth, great to see where, and how accurate, you flew. You can even see the track in 3D (including altitude) on Google Earth.
Fly safe,
JvTonder
Postby JvTonder » Thu Sep 20, 2012 3:51 pm
Rudi ek gebruik ook Mapsource en dit werk maklik ek kort net daai databasis, waar het jy hom gekry?
Groete
J
Rudix
Postby Rudix » Thu Sep 20, 2012 3:58 pm
JvTonder wrote:Rudi ek gebruik ook Mapsource en dit werk maklik ek kort net daai databasis, waar het jy hom gekry?
Groete
J
Ek het 'n deel van home iewers afgelaai, kan nie onthou waar nie en dit gekombineer met data wat ek gehad het. Ek sal hom op CD sit vir jou, wanneer is jy weer by Rhino? Kan hom ook seker vir jou epos, dink nie hy is te groot nie.
JvTonder
Postby JvTonder » Thu Sep 20, 2012 10:08 pm
Groete
J
Is jy saterdag oggend daar, ek gaan 'n draai maak dan kan ek dit kom op tel. Dankie
Rudix
Postby Rudix » Fri Sep 21, 2012 5:01 am
JvTonder wrote:
Groete
J
Nie seker nie, hang van die weer af en hoe laat ek na AAD sal gaan, as ek gaan sal ek jou laat weet anders sal ek seker Maandag gaan.
Postby Tribal Croc » Fri Sep 21, 2012 7:14 am
Rudix wrote: Kan hom ook seker vir jou epos, dink nie hy is te groot nie.
Kan ek ook asb die epos kry :?: xxx
Rudix
Postby Rudix » Fri Sep 21, 2012 8:38 am
Met plesier, ek sien die file is net 82kb so PM my jou epos adress en ek stuur dit sodra ek by die huis is vhpy
Postby Tribal Croc » Fri Sep 21, 2012 10:08 am
PM gestuur ## ##
Dankie (^^) (^^) (^^)
BeanCounter
Postby BeanCounter » Fri Sep 21, 2012 3:04 pm
Thanks for the advice guys. I got it working (through the USB port, nogal) with the help of an IT colleague and it's only going to cost me a intro-flip. (^^)
Postby Tailspin » Sun Sep 23, 2012 6:17 pm
Hi Guys
Some useless info taken from the Web
viewtopic.php?f=13&t=19466
