Rotax 582 300 hr crank inspect at 275 hrs
Triker
Postby Triker » Mon Aug 06, 2012 1:54 pm
Good day fellow aviators
I havent had a chance to speak to an AP or AMO
My aerie is due for the 300 hr inspection. Now my question is. Can I have the 300 hr inspection and decoke be done although its not yet 300 (close @275hrs)?
Thanks for the help
Sad-Ham
Re: Rotax 582 300 hr crank inspect at 275 hrs
Postby Sad-Ham » Mon Aug 06, 2012 4:00 pm
On the same topic...... what is a ballpark figure for a 300 hr inspection and decoke???
Aquilla II ZU-DJS
Wingfield - 124.8
Triker
Postby Triker » Mon Aug 06, 2012 5:28 pm
Ek wil ook graag weet maar is te bang om te vra, so ek knyp en doen maar net.
bobthebuilder
Postby bobthebuilder » Tue Aug 07, 2012 10:03 am
I think that the cost will flucuate wildly depending on who you decide to use. :wink:
Byron Kirkland
wiskeyfoxtrot
Postby wiskeyfoxtrot » Wed Aug 08, 2012 7:17 am
What is entailed in a " decoke " ..... does the motor have to be pulled apart for this ? ... if so, i dont see the point of having to pull a perfectly good motor apart ! ( non destructive test ... yes, but ????? )
Can somebody help with this .... My motor is also coming up to the 300 hour mark !
I shudder to think ! :twisted: :twisted: :twisted: :twisted:
Aeroprakt A22 Foxbat
ZU - DYE
Sport Cruiser
ZU - LSA
Sad-Ham
Postby Sad-Ham » Wed Aug 08, 2012 7:38 am
You can do a Chemical Decoke by running the moter and spraying powertune in through the carbs. I did this at 200 hours and it works well. The problem at 300 is that your crank needs to be inspected and determined whether it needs to be replaced or not.
Aquilla II ZU-DJS
Wingfield - 124.8
bobthebuilder
Postby bobthebuilder » Wed Aug 08, 2012 1:54 pm
I think the crank can be inspected through the plug holes with a vacuum guage. No need to tear the motor down.
Byron Kirkland
KFA
Postby KFA » Wed Aug 08, 2012 7:47 pm
http://www.lightaircraftassociation.co. ... tOct08.pdf
Very interesting reading regarding the 582 crank.
bobthebuilder
Postby bobthebuilder » Fri Aug 10, 2012 8:19 pm
They also speak of of bearing tests, but more importantly, of the stress risers that probably cannot be detected.
.... Okay then .... A tear down is probably the way to go.
Byron Kirkland
mulderpm
Postby mulderpm » Wed Aug 22, 2012 1:04 pm
Speak to an AMO or AP. They don't pull the engine apart for the 300Hr inspection. They measure everything without pulling apart the engine. If something is outside tollerance then they may have to dismatle parts to gain access. If at all possible I would not do this at 275hrs, I would wait for the 300hrs.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
