Density Altitude / Gyro Performance Chart
mak
Postby mak » Sat Nov 19, 2011 2:28 pm
A while back I compiled the following chart for myself and think it will be relevant for most turbo charged Rotax gyros flying in SA. With the current hot conditions this might just be usefull to someone. The first chart is a quick guide to check your density altitude in the absence of accurate data. I know their is more to consider when calculating DA but I tried to average all of these factors. The second chart predicts your Vertical Speed based on DA and weight. The third chart will give you the max weight based on a required vertical speed (to clear obstacles). I am reluctant to convert this info into a take-off performance / runway required chart as this is very runway condition and take-off technique dependant. I know that these data will differ from gyro to gyro because of different rotors, aerodynamics, etc but again it is just a guide only. The chart is not based on the maximum angle and rate of climb, which is normally between 55 and 60mph, but rather on a comfortable 65 to 70mph climb out speed. This then gives you a +-15% safety margin for possible varying conditions.
Gyro Performance Chart (1).xls
(79.5 KiB) Downloaded 184 times
www.altairaviation.co.za
saraf
Re: Density Altitude / Gyro Performance Chart
Postby saraf » Sun Nov 20, 2011 1:56 pm
Hey Mak
Great work , there is an application if you have a iphone that calculates density alt on your phone. Very nice to use.
Eben jnr
THI
Postby THI » Sun Nov 20, 2011 2:11 pm
Wat is die app se naam?
M I Claase
Postby M I Claase » Mon Nov 21, 2011 10:15 am
Mak
Baie dankie dit is goud werd vir rekenaar gestremde mense soos ek. (Ons is nie almal so op hoogte met ipad soos die Upingtoners nie! Vir iemand wat net gyros bou en vlieg het hy my verras! Ek wonder of sy pa hom gehelp het?) Ek kon darem die uitleg verstaan!
Postby Gyronaut » Mon Nov 21, 2011 10:28 am
THI, ek gebruik Pilot Wizz op die iPhone, dit het ook Density Alt en weer ens... baie nice en gratis.
Len
THI
Postby THI » Mon Nov 21, 2011 10:36 am
Gyronaut wrote:THI, ek gebruik Pilot Wizz op die iPhone, dit het ook Density Alt en weer ens... baie nice en gratis.
Len
Dankie Len,
Ek het vinning gekyk na DenAlt, maar daar is nog 'n paar bugs, siende dat die "change units" (F, Ft ens) nie lekker werk nie.
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
