FIBRE GLASS FUEL TANK
hennies1
Postby hennies1 » Sat Oct 29, 2011 5:51 pm
HI
ANY ONE AN IDEA HOW TO MAKE YOUR OWN FUEL TANK. WHAT TYPE OF RESIN TO BE USED, ETC. busy BUILDING A POWERED PARA GLIDER TRIKE AND NEED A SPECIFIC SHAPE.
THANKS
HENNIE
German
Re: FIBRE GLASS FUEL TANK
Postby German » Sat Oct 29, 2011 8:30 pm
I USED THE ORDINARY STUFF YOU BUY AT YOUR LOCAL HARDWARE STORE
KFA
Postby KFA » Sat Oct 29, 2011 8:52 pm
You can not use normal plyester resin, it starts to form a gel in the tank and does not react very well with fuel, especially if the fuel has some ethanol in.
Use a very high quality vinyester resin for the job. Not all vinyester resins are equal. This is the right stuff - DERAKANE 470-300 Epoxy Vinyl Ester Resin
Brief description
DERAKANE 470-300 Resin is an epoxy novolac-based vinyl ester, designed to provide exceptional mechanical properties at higher temperatures. This resin offers a high resistance to solvents and chemicals, good retention of strength and toughness at elevated temperatures and excellent resistance to acidic oxidizing environments.
German
Postby German » Sun Oct 30, 2011 9:32 am
:shock: :shock: Does 95 Vpower contain ethanol,all I use?
KFA
Postby KFA » Sun Oct 30, 2011 2:53 pm
Use the right stuff. Redo that tank. It will bite you some time :shock:
hennies1
Postby hennies1 » Sun Oct 30, 2011 3:45 pm
How many layers are necessary for a tank?
Postby Tailspin » Sun Oct 30, 2011 4:20 pm
hennies1 wrote:How many layers are necessary for a tank?
As far as i know at least 3 layers all round.
you can also slosh the inside of the tank with a 3M tank sealer. ## ##
Postby Morph » Mon Oct 31, 2011 11:55 am
Scotchclad EC 776
Low Level
Postby Low Level » Tue Nov 01, 2011 9:30 am
Hi Guys
Interesting news. I've been thinking a while of trying my hand on a fuel tank. What would one use for a mould ?
ZU-CFW
nickjaxe
Postby nickjaxe » Tue Nov 01, 2011 9:31 pm
Over here in the UK....some guys are having probs with the older fibre glass tanks leaking due to ethanol they think.
Nick.
German
Postby German » Wed Nov 02, 2011 7:56 pm
Only leaking or forming a gel? I am only worried about gel blocking the outlet from the tank causing fuel starvation.
nickjaxe
Postby nickjaxe » Wed Nov 02, 2011 10:23 pm
Sorry I dont know....the ones I know of are Shadow owners...some are fitting alloy tanks to replace the fibre glass ones.
justin.schoeman
Postby justin.schoeman » Thu Nov 03, 2011 9:14 am
nickjaxe wrote:Sorry I dont know....the ones I know of are Shadow owners...some are fitting alloy tanks to replace the fibre glass ones.
This is probably the best idea. For a one-off tank, welded aluminium will probably be a lot cheaper and easier than making a composite tank.
