Ela 08 oil temp running high
Big Man
Postby Big Man » Thu Sep 08, 2011 3:52 am
Our Ela 08 oil temp is running between 110 and 117 deg C with two up.......
What is the best way to bring the oil temp down: :?
1. Install a scoop on water radiator?
2. Install a scoop on oil radiotor? It has got the larger radiator on, as well as thermostat
3. ( suggestions please )
I refuse to grow up.
ZU-CKX; ZU-ERN; ZU-LSC
Low Level
Re: Ela 08 oil temp running high
Postby Low Level » Thu Sep 08, 2011 9:30 am
Geeeez Julius - this is seerious. :shock: :shock: It's keeping you awake at 4 in the morning. Even used Splinter's pen to post the message.
ZU-CFW
Big Man
Postby Big Man » Thu Sep 08, 2011 12:51 pm
(!!) :idea: :oops: :oops:
MAGNIficent
Postby MAGNIficent » Thu Sep 08, 2011 1:05 pm
Big Man,
What does your agent suggest?
How does these temperatures compare with other similar Gyros?
How many hours on your Gyro?
Oil Temperature always been a problem?
What type of Oil do you use?
What is your ambient temperature when you achieve those Oil temperatures?
To fly is LIFE...!!!
Keep on LIVING...!!
t-bird
Postby t-bird » Thu Sep 08, 2011 1:23 pm
The first ELA’s came out with a small radiator which caused overheating. The radiators size was increased which solved the problem.
The oil radiator was also moved more into the airflow on later models.
What is your CHT temperature ?
What is your coolant to water mixture in the water radiator ?
What is your EGT readings ? Could be running to lean
When last were your carbs balanced ?
How many hours on your engine ?
Big Man
Postby Big Man » Fri Sep 09, 2011 5:29 am
M0del 2008
CHT = 80
Coolant = 50/50
EGT Left = 800; Left = 700
Carbs balanced 1 month ago by Glen Meyer @ Springs and serviced
Total hours = 150
Fuel consumtion = 21L/hour at 80 mph; 29 psi; one up. ????
Tempretures high only when 2 up
Outside temp was 23 degees C
t-bird
Postby t-bird » Fri Sep 09, 2011 12:29 pm
What does Glen say about the 100 degree difference on your EGT’ s
Big Man
Postby Big Man » Sat Sep 10, 2011 7:36 am
Glen says the Ela's oil radiator's angle must be changed to 30-40 degrees. ( not 90 )
I fitted a scoop, and it looks like it works.....
Will test it again today.
Big Man
Postby Big Man » Wed Sep 14, 2011 2:46 pm
Oil temp is now fine
Ek het vanoggend my eerste vrou opgevat en ook saam met BONZAI BELL
'n brekkie geniet by Kittyhawk. (Gelukkig weet sy nie van hiri forum nie; tensy Sukkelaar haar vertel ... vhpy )
Ek 145kg; vrou 63kg plus 65L petrol. Oil temp = 108 max.!
Viva Ela 08
BONZAI BELL
Postby BONZAI BELL » Wed Sep 14, 2011 4:40 pm
En ek dog jy het gewig verloor om Saterdag in jou suit te pas???
ZU-EOL
Magni M-22
Splinter
Postby Splinter » Thu Sep 15, 2011 10:54 am
Big Man wrote:Ek het vanoggend my eerste vrou opgevat
Is daar dan n ander vrou waarvan ons ook moet weet pa? hahahahahaha Nou hardloop ek! :twisted: :twisted:
Lower, Lower ...........
t-bird
Postby t-bird » Thu Sep 15, 2011 11:18 am
145 kg pilot - That is impressive !!!!
Big Man
Postby Big Man » Thu Sep 15, 2011 4:17 pm
T-Bird, I'm not big man for nothing...............
