M16 Cockpit Panel CAD file? Anyone?
Postby Gyronaut » Mon May 30, 2011 6:20 pm
Does anyone have the CAD files that they may have done for an M16 cockpit panel please?
I want to have one cut and engraved (Laser) and thought perhaps someone has already done all the measurements etc and drawn it in a CAD file that I can use to fast-track the process.
Len
Learjet
Re: M16 Cockpit Panel CAD file? Anyone?
Postby Learjet » Mon May 30, 2011 8:52 pm
Len, I collected this somewhere along the way if it helps.
M22%20Face%20Plate_3.pdf
(14.63 KiB) Downloaded 319 times
Dave Lehr
Magni Gyro M22 ZU-EPZ
lion
Postby lion » Tue May 31, 2011 7:36 am
Hi Learjet, the file you attached above is for my new M22 coming in a few months. Good meeting you at Gariep!
Len, I have a 16 meg professional full size scale scan (jpeg format) of a blank panel if you need it.
Cheers,
L
Postby Gyronaut » Tue May 31, 2011 8:18 am
You guys rock. Thanks.
Also subsequently discovered that the local Magni agent sells blank panels and the .dfx file for the cutouts.
Will be in touch.
lion
Postby lion » Tue May 31, 2011 9:15 am
Be interesting if you can get the panel laser cut - I have been trying for years with no success.
Waterjet with a pilot hole pre drilled (big mission) has been my best solution with carbon fiber.
Cheers,
L
Postby Gyronaut » Tue May 31, 2011 9:32 am
I'm no expert Lion but I was thinking of a normal anodized aluminium panel for laser cutting. I understand Carbon Fibre burns when laser cut?
flying-i
Postby flying-i » Tue May 31, 2011 10:18 am
Len
Contact Keith Benkenstein on 082-893-5378, he is a club member and this is his business. He has all the relevant machinery etc.
He has sorted many a dash out at the club.
Learjet
Postby Learjet » Tue May 31, 2011 10:20 am
lion wrote:Hi Learjet, the file you attached above is for my new M22 coming in a few months. Good meeting you at Gariep!
Cheers,
L
Hi Lion - nice layout. Not sure where I filched your file from. Sorry :-)
Dave Lehr
lion
Postby lion » Tue May 31, 2011 10:42 am
No prob - I had posted it on this forum previously.
Len,
I have used aluminium for a panel (See Greg Vos panel) and laser cut and then anodized with success.
Yes, carbon fiber just burns with laser - that is if you can even get someone to try, as they run the risk of damaging their laser with the reflection from the carbon.
Magni in Italy however do cut their panels with laser - seems to be a secret how they do it or what strength laser they use.
I cut about 15 dummy panels in supawood first to ensure correct fitting of instruments and no conflicts with the rim of the panel and the gyro.
I used a guy in JHB who did everything on CAD for me, so he has everything on computer already and can move things around. I can give you his details or can assist you in JHB if you like.
L
Magnifan
Postby Magnifan » Tue May 31, 2011 4:23 pm
Len, Abrie le Roux has a CNC waterjet cutter in Somerset West, he may be able to do the cutting for you once you have the layout.
Magni M16: ZU-DIO
Jabbanaught
Postby Jabbanaught » Wed Jun 01, 2011 8:32 am
Affirm , Abrie has helped a couple of guys .
Autogyro - Calidus ZU- ???
Magni M22 - ZU EGA
