Hi Guys
Some trouble shooting ideas please. On way to Port Ellizabeth and back to East London today ,Air traffic noticed my Microair transponder was showing HUGE differences in altitude. Like 2000ft and then later 27000ft diferences on out going signal. Fitted in a Skyranger ,no problems before. Going one way strong headwind and coming back strong tailwind. Actual heights from 1500ft to 2000 ft on altimeter. Suggestions please
Regards Bryan
Traansponder blues
Re: Traansponder blues
Check your static vent on the encoder
Balls to the wall
Balls to the wall
Turn it off...
Agree with Avgas. Check the vents on the encoder and also the connections. There may be a small leak esp if it was turbulent.
Also try testing it in calm conditions. if it is erratic it often a loose connection. if constant usually more expensive....
Hi Guys
Problem sorted. Fitted spare unit I had and opened US unit . found one broken off capacitor and 5pin plug on unit detached. Spare unit working well. Will try to fix old unit to fit to trike!
Bryan
Bryan
