size of seat frame
hennies1
size of seat frame
Postby hennies1 » Sat Mar 19, 2011 7:44 am
Hi
Need info on size of the seat frame for a trike. I am in the process of building a para glider trike and want to install a similar seat to my trike
What is the basic length of most trikes
Hennie
hennies1
Postby hennies1 » Mon Mar 21, 2011 10:46 am
Info
Grumpy
Re: seat frame of trike
Postby Grumpy » Mon Mar 21, 2011 11:17 am
hennies1 wrote:It seems nobody on the forum owns a trike, or a measuring type. (^^)
More than 50 viewers and no help?
You cant be serious, hennies1 :shock: :shock: :shock:
There are about 20 different types of trike makes, models and configurations. So let me know which one you are looking for and as soon as i have that info I will go around the country, try and locate the specific one you are looking for, try and locate the owner, get permission, or ask him to come to the hangar, open up, and let me in with a tape measure and...... ($$) ($$) ($$) ($$)
GO MEASURE A TRIKE .. don't you think?
ystervark7
Re: size of seat frame
Postby ystervark7 » Tue Mar 22, 2011 1:43 pm
Grumpy maybe you can just measure your back-end from one side to the other vhpy
OK I am building a trike so maybe I can give you some idea. The seat frame width, side to side, should be between 400 and 500mm. 440mm is sort of in the middle and should be good enough for most seats, except may in Grumpy's case.
The depth is not so exact because the seat sits at an angle. The bottom is approximately 380mm but it occupy about 500mm from the front edge to the back.
The basic length of a trike is about 2.8m from the propeller to the front but I am not sure why you want to know this?
A trike seat might be a bit of an overkill for you. A trike seat needs side support for steering which I do not think you need.
hennies1
Postby hennies1 » Thu Mar 24, 2011 2:21 pm
Thanks Ystervark
At least there is one person that's prepare to help me thanks. I thought that this forum was to help and support each other .
Grumpy
Postby Grumpy » Fri Mar 25, 2011 10:12 am
hennies1 wrote:I thought that this forum was to help and support each other .
It is hennies1, it also allows for a bit of chuckle occasionally. (^^) (^^)
Dish
Postby Dish » Fri Mar 25, 2011 12:15 pm
Hey Grumps Looks like we got a sensitive one here !!!! ha ha - heres the way it works
The okes are very very supportive, half the time most of what they say is in jest and the rest of the time they have had a few beers!!!!
Many many okes will look at the topic and scan through it, if they dont know they wont answer - hence 50 views and 1 answer.
Supportive??? read D20's story on giving up the dream, thats support right there
When they do answer it will be a good one and more than likely helpful
"Thanks Ystervark
At least there is one person that's prepare to help me thanks. I thought that this forum was to help and support each other ."
Pity Party over ???? (^^) (^^)
RV9
DISH
