Jab engine in trike
Jab engine in trike
Postby RV4ker (RIP) » Wed Nov 17, 2010 11:25 am
Don;t know if this was on here...
Interesting development is this 2200 adapted engine currently undergoing testing for the push application in un-cowled environment of the likes of trikes or ultra light aircraft.
From a Jab factory visit report back on Avcom
http://www.avcom.co.za/phpBB3/viewtopic ... 00#p810114
rooikat
Re: Jab engine in trike
Postby rooikat » Fri Dec 10, 2010 2:00 pm
I was told once that Jabi engines tend to overheat when mounted in pusher configuration which is why you don't see too many of them mounted on trikes. Any truth in this?
The cost alone of a Jabi engine over a Rotax would seem to make it a more logical choice, never mind the more pleasant, friendlier sound of a 4-stroke running a lower and more mechanically-sympathetic RPM :twisted: Better than a screaming, expensive, low-TBO two-stroke any day.
justin.schoeman
Postby justin.schoeman » Fri Dec 10, 2010 2:07 pm
rooikat wrote:I was told once that Jabi engines tend to overheat when mounted in pusher configuration which is why you don't see too many of them mounted on trikes.
Pusher is not a problem - just ask Rudix...
Very low airspeed and pusher config may be a problem - which is why Jabi is testing this forced air cooling solution.
rooikat
Postby rooikat » Fri Dec 10, 2010 4:09 pm
Yeah, that makes sense. The overheating tended to happen on the ground, during taxi or while the aicraft was standing still.
The solution will be one to watch. For me it would transform the idea of microlighting - that two-stroke shriek is real turn off for me.
