Camera mounting position.
- bobthebuilder
If I wanted to mount a camera on my trike, where is the best place to put it?
Any bracket ideas?
Any bracket ideas?
Byron Kirkland
Re: Camera mounting position.
hi , for videos , on your bar at your R/H if you are R/H or then on your L/H . Have nice videos in that possie, for pic's i will say hang it around your neck.
- bobthebuilder
The bar seems like a convienient place, but does it not get in the way when the wing is moved fully to the side, like when parking in windy conditions?
I had thought of the profile tube, but this is a real stretch to reach.
Maybe around the neck is the best place. I do have my doubts about the laniard fasterner on the camera though.
No other ideas?
No other ideas?
Byron Kirkland
- Alpha
Hi Byron,
I have been looking for a good mount for a while now and what I have found is something called the Pedco UltraClamp. This will fit nicely onto the bar of the A-Frame and is very secure.
The only problem I have with it is that you cannot rotate or pan the camera while flying, but is very sturdy in flight with no vibration.
I attached a pic for you to see. You can get it from a place in Northclif called action cameras.
http://www.actioncameras.co.za
Fly Safe
Gary
Fly Safe
Gary
- pedcoultra-01.jpg (37.39 KiB) Viewed 2483 times
ZS-WGT
ZU-AAS
ZS-WGT
ZU-AAS
I attached a piece of aluminium angle iron with clamps onto the bar (about 80mm) and use a 'window' camera mount, obtainable from any camera shop, secured with cable ties. The mount can be moved up/down/left/right and even rotated. See attached.
- CameraMount.JPG (17.81 KiB) Viewed 2469 times
Caught a dream............
Windlass Aquilla
Thunderbird MKII
Savannah VG
Windlass Aquilla
Thunderbird MKII
Savannah VG
Has anyone got a Gorrial Pod, I've seen they can be pretty versatile to mount in odd configurations, don't know if they are stiff enough to hold up to trike speeds though.
http://joby.com/gorillapod
- Ledz
- Ledz
- bobthebuilder
...... OK, it seems that everyone is using some derivative of a commercially available mount.
Thanks for the leads.
Byron Kirkland
- bobthebuilder
Thanks a lot Carl,
What time will you be at the Octoberfest?
Byron Kirkland
I believe I am to wear one of those dayglo orange jobs, so I will be there early in the morning - probably from 6:30 onwards..
If I can convince my softness to fly with me, I might be there earlier..
I've included an enlarged picture of it, on the profile tube, using two cable ties, and it works well enough for me..
- Mounting.JPG (4.84 KiB) Viewed 2406 times
ZU-DODO
These guys are also very good for all types of mounts
http://www.ram-mount.co.za/t/b-sized-mo ... ra-mounts/
- Biggles
I have a similar set up to alpha-a-sierra's picture. Mounted just to the right of the hand grip on the bar. It is close enough to use and far enough to be out of teh way. You need to memorise where the camera selector knobs positions as its damn near imposible to see when flying. I am now used to it and have a canon 500D with a 12mm fish eye on it. Takes good video and stills. I still want to fit a remote shutter release closer so I don't have to lean for stills.
warning. This puts a torsional stress on your bar that its not designed for, especially if its a large DSLR set up like mine on a high mount.
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
- bobthebuilder
Hi Biggles,
If there was an accident, this is classified as an unapproved mod right? Implications?
How much torsional stress can it put on the bar? The camera is a hand held device and should be fairl light, and as long as it is mounted close to the bar, (short moment, (minimal leverage)) I cannot see it placing the bar under much stress ....... or am I missing something?warning. This puts a torsional stress on your bar that its not designed for, especially if its a large DSLR set up like mine on a high mount.
Byron Kirkland
- Biggles
I have a large camera, and the mountings get quite tall once you have the bar clamps and the adjustment gimball and the attachment to the camera. And considering the bar is not designed for any twisting motion. Just something to keep in mind.bobthebuilder wrote:Hi Biggles,
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
- Biggles
http://www.actioncameras.co.za/rollbar_mount.html
Try this link if you want a mounting for the control bar.
Trike pilot
ZU-DLP
Winelands FAWN
ZU-DLP
Winelands FAWN
