Jack wiring on headsets
izak01
Found a flight school
Postby izak01 » Tue Mar 30, 2010 12:05 pm
Is daar dalk iemand wat vir my kan verduidelik hoe om die 2 jacks wat aan n headset is te bedraad. Ek het peltor headsets en die jacks maar het nie n idee waar die draadjies moet kom nie. :roll: Die microlight het n buzzcom interkom. Hoop dit is genoeg inligting.
Groete
Izak
Re: Jack wiring on headsets
Postby Morph » Tue Mar 30, 2010 1:06 pm
Call them, I'm sure they will be able to fax you a diagram
Tel: +27 (11) 452 0663
KFA
Postby KFA » Wed Mar 31, 2010 1:04 pm
The small one is the mic and the large one the headphones. Check the intercom wiring diagram and then make your headsets the same. I will see if I have a diagram and will post it
KFA
Postby KFA » Wed Mar 31, 2010 10:22 pm
Can't find a usefull diagram. All the ones I have is for a specific radio or intercom. Here is a link that might help http://www.headsetsinc.com/wiring_diagram.pdf
KFA
Postby KFA » Wed Mar 31, 2010 10:27 pm
Some more
Intercom wiring diagrams.pdf
(30.53 KiB) Downloaded 142 times
alan
Postby alan » Thu Apr 01, 2010 10:46 am
Does anyone know where to buy the little jacks (male side) on headsets? Large ones are freely obtainable but smaller ones seem to be a problem.
Waiting for the wind to stop
izak01
Postby izak01 » Thu Apr 01, 2010 10:05 pm
KFA
Baie dankie vir die inligting ek het uiteindelik reggekom.
Alan
Aviation engines verkoop hulle. Sit maar as jy die prys vra :(
Groete
Izak
