Take off weight - Raptor - Solved
Alkemac
Postby Alkemac » Fri Oct 16, 2009 8:30 am
Is there a difference between
the maximum take of weight of a Raptor
and
the weight of a pilot, passenger & luggage with a full tank ?
ZU-DODO
Jetman
Re: Take off weight - Raptor
Postby Jetman » Fri Oct 16, 2009 9:53 am
Maximum take off weight is the combined(total) weight of the aircraft and all the extras that you're going to take off with.(under carriage, wing, instruments, wheels, passengers, luggage, tools, fuel, oil, engine, chocolates, coffee, ect).
Cheers Skin
ZU-FDE Apollo Delta Jet
ZU-IHK Sling
ONE LIFE....LIVE IT
Alkemac
Postby Alkemac » Fri Oct 16, 2009 10:01 am
Thanks Skin..
Could I safely say then that 450kg's applies to both ?
ZU-DODO
Wargames
Re: Take off weight - Raptor - Solved
Postby Wargames » Fri Oct 16, 2009 6:43 pm
Alkemac wrote:the weight of a pilot, passenger & luggage with a full tank ?s
If you add undercarriage, wing and engine to the above, you have the same as MTOW. vhpy vhpy
Jetman
Postby Jetman » Sat Oct 17, 2009 9:57 pm
Yes, 450 kg's applied to both
Skin
ZU-IHK Sling
ONE LIFE....LIVE IT
