Rotax and Avgas
Tracer
Rotax and Avgas
Postby Tracer » Fri Mar 13, 2009 12:36 pm
Can you use Avgas (premixed) in the Rotax 503 / 582? What will the effects be? :?: (**)
Stephan van Tonder
Re: Rotax and Avgas
Postby Stephan van Tonder » Fri Mar 13, 2009 12:46 pm
Unless you getting it for free why on earth would you want to?.
Tracer
Re: Rotax and Avgas
Postby Tracer » Fri Mar 13, 2009 1:00 pm
Well, we planning a nice flight and will need to refuel, I suspect the wife will join on the trip, so can't carry extra fuel. We want to stop over at FAPN (Pilanesburg), and they only got Avgas. Considering all options here. The easy one obviously will be to send a groud crew there with fuel, but where's the fun in that? (^^)
Wargames
Re: Rotax and Avgas
Postby Wargames » Fri Mar 13, 2009 1:12 pm
Tracer wrote:Can you use Avgas (premixed) in the Rotax 503 / 582? What will the effects be? :?: (**)
I'm no expert, but what I have heard, is that it will work fine, but your fuel consumption will be a lot higher.
You need to find more advise on this. Maybe phone Niren at AE!!
Re: Rotax and Avgas
Postby RV4ker (RIP) » Fri Mar 13, 2009 1:19 pm
Should not be a problem?
AndyG
Re: Rotax and Avgas
Postby AndyG » Fri Mar 13, 2009 1:24 pm
Back in the early days that is all we used to use. You will be fine.
Tracer
Re: Rotax and Avgas
Postby Tracer » Fri Mar 13, 2009 2:18 pm
Cool, thanks guys. (^^)
Stephan van Tonder
Re: Rotax and Avgas
Postby Stephan van Tonder » Fri Mar 13, 2009 3:07 pm
There is no problem and it won't change a thing - also no change in fuel consumption(don't know where that comes from). If that is all you can get hold of use it. Was just thinking to myself that it's really expensive fuel to use in an engine that has no benefit or need for it.
AndyG
Re: Rotax and Avgas
Postby AndyG » Fri Mar 13, 2009 3:41 pm
In the "old" days it used to be cheaper than Mogas.
Splinter
Re: Rotax and Avgas
Postby Splinter » Fri Mar 13, 2009 3:48 pm
We have done many trips where we had to top up with avgas on the 912 and have never had any problems! Even works fine if you still have mogas in the tank and you need top up! Also no change in consupmtion!!! But we have always gone back to mogas asap!
Enjoy
RED
Lower, Lower ...........
Arnulf
Re: Rotax and Avgas
Postby Arnulf » Fri Mar 13, 2009 9:35 pm
Splinter wrote:We have done many trips where we had to top up with avgas on the 912 and have never had any problems! Even works fine if you still have mogas in the tank and you need top up! Also no change in consupmtion!!! But we have always gone back to mogas asap!
Enjoy
RED
On the 4strokers Rotax recommend a shortend oil change interval due to the high lead content.
To be sure, check your engine manual.
Splinter
Re: Rotax and Avgas
Postby Splinter » Mon Mar 16, 2009 9:24 am
Enjoy
RED
That is correct but I dont think half a tank every 100 or 150 hours cant make a very very big diff. Try to only use it when you cant get hold of mogas and then change back asap
RED
Re: Rotax and Avgas
Postby Morph » Mon Mar 16, 2009 9:33 am
You are completely safe to do so, the only negative effects, apart from the price of course, is on a 2 stroke your plugs gunge up quicker and on a 4 stroke, extended use will require oil replacement sooner.
Re: Rotax and Avgas
Postby Gyronaut » Mon Mar 16, 2009 11:36 am
I've been told on the 912/914 Rotax its good to run it on Avgas occasionally.
Don't remember or know why meself? Can the guru's enlighten me?
Len
Stephan van Tonder
Re: Rotax and Avgas
Postby Stephan van Tonder » Mon Mar 16, 2009 12:49 pm
Nope - 912/914 made specifically for unleaded. Nothing good about running it on avgas. Fouls the plugs and gets deposits on the back of the valves.
