TOYOTA YARIS ENGINE
Re: TOYOTA YARIS ENGINE
Enjaain going into my Explorer this afternoon.
- John Boucher
Moet ons nou net nie tart nie.... fotos asseblief ou grootte!
Hallo,Boet!Die branch lyk goed en netjies.
Kan nie wag om te sien hoe n TOY van die outa vlieg nie.
Die 1000cc ontwikkel 80hp?
Ek het sondag gehoor van n persoon wat sy bmw engin af gehaal het van sy trike.Die engin het te veel krag en dan trek die trike side ways
FLY SAFE!!FLYBOY OBD
My aerie now got big lump on the nose. Niel, from Kroonstad will make the belt-drive system. Me and the 2 lads picked the engine up from the floor, and hung the engine. This lump is very light. So far, so good. Exhaust manifold welded together. Altenator fitted. The wiring........
oooooooooo @ok
- right view.JPG (43.72 KiB) Viewed 4297 times
- Enjaain in.JPG (43.38 KiB) Viewed 4288 times
TX Rick, still a ways to go before we can fire it up he? I have contacted Toyota`s boffins for some assistance with the wiring. LOTS of spaghetti!!
Starting to look very good Boet
Keep going
Keep going
Had call back from my contact at Toyota. No, sorry, they can not be of assistance, because the Yaris is a complete import........ Thanks fer faaakaaaaal.
- KFA
Probeer hier
http://www.the12volt.com/installbay/for ... ?TID=81694
http://d.scribd.com/docs/2mjdcmhlsjbm63mpls1r.pdf
Ek het jou 'n afskrif gestuur
- John Boucher
Ja Ja most of the motor manufacturers have become part swappers... Have absolutely no clue of the mechanics or electronics of the vehicle if they don't have the manufacturer specific Diagnostic Systems to tell change this sensor or refill the aircon gas!
Interesting to note that Peter Funk had to contact Daimler when using the Smart Diesel variant in his green project and they were quite accommodating. If I am not mistaken the development team of Bosch assisted them with the black boxes etc. That complete conversion was in the region of 10 to 15 thousand Euros! Would have worked quite well if the exchange rate had remained where it was back then!
You go Boet....
You go Boet....
And REAL mechanics are getting scarcer by the day. Became more like "fitters" : Remove old part and fit new one. When I learned this trade, it was maak n plan dat die kar kan loop!!
- John Boucher
Thanks John. Very smart of you to point the smart out to me, but I will keep on doing my smart thing, and be smarter by using a smarter engine, of wich the price really will be very smart!!
Oh, and BTW, check out THIS site: ecoyota.neuf.fr VERY smart.
- John Boucher
Struggled with the French... I only eat snails you know! Then did a search an this is what I found....
http://neuf.recherche.aol.fr/aol/idoidP ... %2F17.html
The point is and rightly researched by you Boet and others is that there is life after ROTAX (RIDS - Rotax Induced Divorce Syndrome)
