Polishing Lexan
Carel
Survived first engine out
Re: Polishing Lexan
Postby Carel » Wed Sep 17, 2008 11:04 am
Silvo will remove some of the milkiness. Finish off with a none glaze and none abrasive good qaulity car polish. Stay away from car polish that remove oxidation and faded paint.
Restored both my helmets visor`s to 99% of new their new condition.
Re: Polishing Lexan
Postby Boet » Thu Sep 25, 2008 8:50 pm
Mmmmm. And another one that also listens to sound advice. If the scratch is deep, sand it out with 220 grit wet sandpaper, then 400 grit....and 1200 grit, followed by rubbing compound. Very course stuff, followed by burnishing compound, and a final work-out with Silvo. By then you will have forearms like Popeye, but your windows will be nice again. If the whole window becomes "milky", there is no cure. Replace. I have seen some of these expensive imports with these milky windows. Cheap lexan.... :roll: :wink: (-)
Massimo
Re: Polishing Lexan
Postby Massimo » Tue Oct 21, 2008 8:49 am
The one is spelt "SILVO" and the other is spelt "BRASSO" :lol: xxx puff
Massimo
Re: Polishing Lexan
Postby Massimo » Wed Oct 22, 2008 7:59 am
Demon i really would not know. Boet seems to only use Silvo while others use Brasso. I tried Brasso and it worked ok but no fireworks, maybe you use Silvo and then report back?
James Bentley
Re: Polishing Lexan
Postby James Bentley » Wed Oct 22, 2008 8:13 am
3M make a complete polishing kit for Lexan & Perspex windscreens
It comprises of abrasive papers right up to 2000grit and polishing creams
Works very well, but lots of elbow grease required to remove deep scratches
Be careful of any liquid/polish that may contain solvents or ammonia, they can soften the substrate which could result in the milky appearance.
Good luck!
James
Airfield EVA'S FIELD
Home EVA'S FIELD
Work Pietermaritzburg
James Bentley
Re: Polishing Lexan
Postby James Bentley » Thu Oct 23, 2008 7:14 am
Hi Demon
Yes, have flying machine in hangar. X-Air, 582 powered. Won't keep up with the GT's but great fun.
Will be good to see you guys again, we will arrange for a new big batch of crunchies (^^) (^^)
Cheers & regards
James
Home EVA'S FIELD
Re: Polishing Lexan
Postby Boet » Thu Oct 23, 2008 8:31 pm
vhpy Silvo is much finer than Brasso. Does a far better job for the final polish.
