Dear Tipsy Flyer I used to own aTipsy Nipper a wonderful aircraft. The foam is poly-urethane foam from Aerothane in CT you can give me a call on zero eight four nine seven five triple three one.
Cheers Oupa-G
Cheers Oupa-G
Vroulief moet asb nou net my rug met Voltaren gel in smeer. Heeldag gewerk dat die byle huil. All the bits that does`nt look like a cowling has been sawed and sanded off. Amazing to think that an engine lurks inside that lump of foam.
Hard work, but satisfying. Strangely enough, this foam can be sanded using pieces of offcut foam.(Works best!) By late afternoon we had the shape ......ahh.....wellll...shaped.
Now we are sealing all the foam pores with microballoons and poyester resin. A sticky job. We also get rid of most of the uneven spots. Tomorrow we cover it with one layer BID glass, and then some more filling and some more SANDING.
eeeiiish. Now is Oom en Jan happy with the shape??
- This, belief it or not, is the major shaping tool for an aircraft cowling.
- 100_2911.JPG (64.56 KiB) Viewed 7228 times
- This is a very messy job, those shavings go in EVERYWHERE, and the stick, and itch!!
- 100_2912.JPG (74.72 KiB) Viewed 7245 times
- Most of the pieces not looking like a cowling has been sawed away.
- 100_2917.JPG (70.01 KiB) Viewed 7243 times
some more cowling.......
- Getting there.....
- 100_2949.JPG (67.72 KiB) Viewed 7205 times
Wrong botton.....
- 100_2953.JPG (69.75 KiB) Viewed 7169 times
- Makou-kak blikkie to cut out the light recesses.
- 100_2956.JPG (79.25 KiB) Viewed 7178 times
- 100_2960.JPG (68.65 KiB) Viewed 7188 times
- Cloud Warrior
- Top Gun
Wow - it appears to be a really high tech operation you have there Boet..........
Solowings Aquilla
32-4817
32-4817
Oom Boet ek wil net se dat oom en oom se span doen een ongelooflike job daar in loeries!!!Die cowl lyk fippen smart!!!
Ek kom desember daar deur op 'n bike toer, as ek mag sal ek baie graag daar by oom-hulle kom draai!!!
Sterkte met die res van die projekte!!!
Speed is live
- Low Level
Boet dit is nou impressive -
- and all in a days work.
Daar is darem maar net boggerol wat experience beat.
ZU-CFW
ZU-CFW
Boet, Dom vraag meskien. Kan jy daai mould weer gebruik om die volgende cowling te maak? Of nou nog n paar te maak voor jy hom moet uitmekaar maak?
- KFA
Die mould word as a template gebruik om 'n negatiewe te maak waarvan daar dan weer cowls gemaak word.
(The foam "mould" is used as a template (plug) to make a "negative" mould that is then used to make the cowls)
Yes Yes verstaan. Makes sense. ThanksKFA wrote:Die mould word as a template gebruik om 'n negatiewe te maak waarvan daar dan weer cowls gemaak word.
Dankie manne.
Vandag het ons noch einemal geskuur dat die k@k wit sit. Nou is die "plug" amper so glad as wat ek hom wil he. Unfortunately my mik en druk acted up today, so no pics tonight.
Sorry..... Hopefully can get it going or borrow a replacement from the small sofness.
While me and Esteban were slaving awayon the cowling, Willem has been as busy as a one legged man at an ass kicking contest. All 3 aeries have door skins and the luggage boxes all have alu floors, and most of the controll systems is in. I HAVE to finish the cowling mold before I can carry on with anything else. We are keeping VERY busy at the moment, too much work for three sets of hands. but I am thankfull. Some of my mates are complaining of slack bussiness and not enough work......
Grumpy, in all probability we will have to break this plug to get the mold off. Not nice.
But once we have the mold, we can make as many of those cowlings as we want!
- Net om die wat belangstel, LUS te maak.......
- m09.jpg (18.1 KiB) Viewed 6924 times
Boet dit is pragtig en ek dink dat op die oomblik loop die Loeriesfontein manne voor in die resies. Die binnekant van die cowling se detail is still a whole new set of tricks. Send my regards to the other four hands and vroulief.
I will post pics and our advances over the weekend
Cheers Oupa-G
Cheers Oupa-G
Boet goed gedaan jochie!
Veilen dank jonge, jij moete jouw hier op Loeries kom vestig dat jy mij kunne kom help met de scuurwerke!! Sanded, painted, then sanded some more......then painted again, for some more painting on Monday. I am completely bushed, going to bed now to collapse and flatline. Moeg en tired. Kort deep-deep heat en n paar sawwe hanne.
- Painting.JPG (63.5 KiB) Viewed 6772 times
- Sanding.JPG (72.08 KiB) Viewed 6778 times
- Doors and floors.JPG (77.06 KiB) Viewed 6786 times
Boet very very nice
Oupa-G
Oupa-G
