You have a 582 right?
Rotax 532/582 DC main jet 165 idler jet 55 jet needle 2.72 needle jet 11G2 clip from top 3 airscrew 1.0 turns from closedFrequent Flyer wrote: I also checked the main jet size - 158 and the needle jet is a 11G2
Rotax 503 DC main jet 158 idler jet 45 needle jet 2.70 jet needle11K2 clip from top 2 airscrew 0.5 turns from closed
It looks like you have 582 needle jet but 503 main jet. If it is a 582 your main jet is too small and thus running lean and hot
So instead of all of us actually believing the EGT's we assumed they were faulty. Meantime, it actually is the wrong jet size. Lesson learned. Is it possible that these carbs were taken off a 503 and installed onto the 582? The main jet size and the clip position seem to indicate so
