Rotax and Foxbat Pilots
Re: Rotax and Foxbat Pilots
Postby Boet » Wed Jan 02, 2013 3:33 pm
priester wrote:
Boet wrote:Sorry for seeing this thread only now.
1 I NEVER wrap the exhaust pipes. ( I had to do a VERY tricky engine-out landing on a test flight with a NEW aerie. Not nice to be flying with a smoke filled cocpit. Briekmerke, manne!)
2 Those 2 plastic overflow pipes gets routed as FAR away from the exhaust system as is possible. These pipes and their well beiing is a pre-flight item BEFORE EVERY FLIGHT.
3 If your 912 installation does not have a feed-back restrictor on it`s petrol system, consider it un-airworthy until fixed.
Thanks Goose, for bringing this problem under our attention. We will "keep`em peeled!!"
A Bells for that Goose!!
Fly safe, and remember: NEVER TURN BACK WHEN U HAV EFAT !!!!!!
Buti, I routed those 2 little vent pipes away as far as possible, right to the bottom of the cowl. The very first flight after this brainwave I had an engine failure at 400 feet just as I increased speed. I landed, cut the pipes and since then no problem.
Oom Priester, op n seker ouderdom kry ons nie meer "Brainwaves" nie, dit neig merendeels hier so n "brain fart se kant toe". :lol: :lol: :lol: :lol:
BE WARNED: You must be carefull not extend the pipes to be in the low pressure area at the bottom of the cowl.
Postby Boet » Wed Jan 02, 2013 3:37 pm
priester
Postby priester » Wed Jan 02, 2013 4:11 pm
Werk jy nie meer nie? Dankie dit is moerse snaaks,
maar dit is nie moerse snaaks dat dit die waarheid is nie (^^)
Postby Boet » Wed Jan 02, 2013 8:26 pm
Jaaaaa, Oom Priester, die waarheid is tog so n bl^#@sem! As jy weer hier verby kom, bring biekie meer tyd saam. Dit was moerse lekker om jou slag te siene te kry! Lekkertes vir 2013! (^^) (^^)
microlightadventures
Postby microlightadventures » Thu Jan 03, 2013 7:03 am
Hi Guys....i have many hours on these machines and am surprised at the amount of accidents in them and i definately agree with the comments above of returns to tank and a short vent hose that is pushed into fuel bowl clip max 4 inches or so.....the only problem is if fuel leaks out of the vent line then onto a hot exhaust)you need to catch this overflow due to blocked idle jet)....some have these hoses to a airbox which is safer and works quite well .....as far as fire on impact goes,the only thing i can think about is perhaps the wiring of fuel guages to the tank censors as these tanks are actually well made and installed and pretty impact resistent....our ZU DIV has a 1000 hrs and going well.....more comments and thoughts would be appreciated and condolences to the families on this sad loss......RIP....Andy Kaspersen 0826517317
