Porra out at Kyalami
- Duck Rogers
Re: Porra out at Kyalami
They gonna send you an invoice for cleaning up the oil!
- Porra
- Survived second engine out
Duck Rogers wrote:They gonna send you an invoice for cleaning up the oil!
"Always remember.... You're unique..............just like everyone else...."
- Stephan van Tonder
- Porra
Stephan van Tonder wrote:Dropped valve?.
Most common problem. Stock Exhaust valves or did you change them beforehand?.
- Porra
Stephan van Tonder wrote:Most common problem. Stock Exhaust valves or did you change them beforehand?.
Watched Rapid Motion last night, never saw the Blow up but very cool non the less
You got some good airtime in the 1st heat.
- Porra
Thanks Dre'. Pays to make some misstakes then heyDreman55 wrote:Watched Rapid Motion last night, never saw the Blow up but very cool non the less![]()
I used to rev mine to 7800 and never had a valve touch becuase of that. When they do touch is when you downshift and let the clutch out and it overruns the rpm bigtime - also sometimes cause the belt to jump a tooth. As a matter of course we used to swop the stock Exhaust valves for a solid stainless valve - the stock valve is sodium filled to transfer heat better but it makes them weak.
- Porra
Hey Stephan, i hear you. I have never had so much s#&t with a golf engine. Used to race them back when it was still the "GTi challenge" in 1996. Also, had stainless valves originally and they lasted all of about 45 seconds. Confused us all including Shaun van der Linde. We put everything together and started the engine and about 45 sec later bang, 7 valves bent at idle. Shaun eventualy found that the front cam cap had a slightly tighter clearance and was gripping the cam and it stripped the belt. How is that for s#@t luck!!!Stephan van Tonder wrote:I used to rev mine to 7800 and never had a valve touch becuase of that. When they do touch is when you downshift and let the clutch out and it overruns the rpm bigtime - also sometimes cause the belt to jump a tooth. As a matter of course we used to swop the stock Exhaust valves for a solid stainless valve - the stock valve is sodium filled to transfer heat better but it makes them weak.
That's a bummer. The guy that put the head together should have picked that up..
