Ian's Savannah Project
RudiGreyling
Postby RudiGreyling » Fri Dec 01, 2006 9:11 am
Ian wrote:<SNIP> Colour is called 'Cream Buttermilk' . <SNIP>
Ian wrote:<SNIP>maybe I should be careful about spilling boiling coffee though... just in case<SNIP>
Now careful there Ian, with all this talk of heat, hot, Cream Buttermilk and Coffee...maybe we should nick name your plane Cremora! :twisted: A Couple of good slogans they've got: "Lite and Creamy" Sounds good, matches your Savanah. Only Joking!!!
Or even: "It flies so nice - Cremora!...give me more ya! "
Only Joking
http://www.RudiGreyling.com
Postby Morph » Fri Dec 01, 2006 4:03 pm
Cool, literally
Ian
Postby Ian » Sat Dec 16, 2006 9:54 pm
OK fellow Microlighters...
After the bashing I took in the previous posts (he he) I decided to take off to the Berg and S Coast 'going nowhere slowly' for a while.
Back at the grindstone progress is below...
Made a little 'spray booth' to take care of the little pieces....
Glued in the firewall, real messy job with contact glue and plenty itching...
(the firewall is made of yellow fibreglass, similar to our think pink stuff for insulating roofs)
Firewall completed together with the 'upholstery' glued into place.. Starting to look quite cosy !
Clear coat sprayed the front fork and fitted the axle re-inforcers (suggested by a Dutch builder Joop, dont really want to loose the front wheel, it will damage the firewall) ..
oh... Rudi, the Sav is not gonna be called Cremora ... its not on top...
Do you know what farfalla is ? Well that's the Italian name, but I'm gonna use the French translation ... any guesses ?
ian
Griffin
Postby Griffin » Mon Dec 18, 2006 1:44 pm
Float like a ... Sting like a BEE??
Papillon
(Non ho saputo che Ian era un nome italiano :? )
Ian
Postby Ian » Sat Dec 23, 2006 9:20 pm
Griffin wrote:Float like a ... Sting like a BEE??
Papillon
Great shot Sir ! - spot on.. :D
No, Im not Italian, but this kit comes from Italy.. so I asked a friend for the Italian translation, but it doesnt sound right for something thats designed to fly in the bush..
An update:
Got the pedals installed..
Fitted a thicker stainless steel plate on top of the front strut on recommendation of John Waterson, apparently the standard plate can bend if landing on very rough tracks (front strut doesn't have a shock absorber, just a thick ruber bungee)
Next I'll tackle the controls..
Finally a 'test drive' using a 'seasonal control stick'
Have a good Christmas, and drive/fly safely !
Cheers ian
Ian
Postby Ian » Sun Dec 31, 2006 9:37 pm
Last post for 2006, hopefully not posting this time next year as I should be flying ...
Installed a whole lotta stuff in the fueslage, things like the flapperon mixer along with the contol rods, elevator belcranks, strobe light box etc.
Assembled the control stick and flap lever.
Completed the windscreen, and then just had to mount the motor in 2006.
Cheers ian
RudiGreyling
Postby RudiGreyling » Tue Jan 02, 2007 11:30 am
Hi Ian,
Looking very Good!
No bashing intended, just joking, responding to others posts..Did my 3 axis conversion on the one at Springs over the Xmas holiday. Nice little 'sporty' plane, enjoyed it, sure you will as well. The #2 notch of flaps suprised me, the runway fills up the whole windscreen bottom to top, that is how steep and slow she can come in.
Ian
Postby Ian » Thu Jan 11, 2007 8:54 pm
RudiGreyling wrote: Nice little 'sporty' plane, enjoyed it, sure you will as well. The #2 notch of flaps suprised me, the runway fills up the whole windscreen bottom to top, that is how steep and slow she can come in.
Yep, I cannot wait, difficult to build to a standard while just wanting to be in the air, good lesson in discipline control..
I achieved what I set out to do this year end, got the rest of the aerie painted.
Below are the wings and struts after priming
Below one of three trips to get all parts home again...
Here the wings are hung again, waiting for Dynatrol to be sprayed inside them..
Last is the rest of the flying surfaces awaiting re packing this weekend...
So Rudi.. , plenty more Cremora now hey ... ! :D
Cheers ian
Thunderboy
Postby Thunderboy » Thu Jan 11, 2007 9:09 pm
Its getting exciting now Ian - can't wait to see it
Thunderbird ZU-ECX
RudiGreyling
Postby RudiGreyling » Fri Jan 12, 2007 2:23 pm
Very nice!
Postby Tailspin » Fri Jan 12, 2007 2:55 pm
Really snazzy Ian !!!!
Ian
Postby Ian » Fri Jan 19, 2007 10:21 pm
Sooo, now I'm in the last 20% which reputedly takes 80% of the time...
So, what is this filter doing below the seat ?
At the beginning of the project I decided I needed fuel flow, so I chose the MGL maxi single which provides defferential fuel flow (subtracts the return line from the main line to provide actual)
Renier (MGL) claims the sensor has to be far away from pumps etc that provide pulsating flows etc that add to inacuracies, so the only place to put the sensor is after the header tank (behind the seats) and before the pump in the engine bay.
But you need to add a filter befor the sensor (small bitties of dirt could end your day unhappily) , then to change the filter without emptying the tanks in the wings you need a fuel cock, so all of a sudden you have to add 160 gramms of weight...
The valve, note the safety wire, I dont think you want this to close on its own ... Only used when you change filters.
Here's the whole lot on the bench while working out pipe lengths etc..
The final installation beneath the pilot's seat. Still gotta secure the electrical wire.
And all this takes time... but I guess you gotta do it right..
Oh, the filter is a good find, wer'e all using the MB diesel filter which is great but you cannot see through it, this filter is the Bosch equivalent (mesh filter) which is see through. Part number is 0 450 904 077 and costs around R18.
Cheers ian
RudiGreyling
Postby RudiGreyling » Mon Jan 22, 2007 11:18 am
Hi Ian,
Looking good! Good find on the filter, looks like a good replacement for MB.
I'd like to get one and compare it to an old MB one that I'll cut open to compare...where did you buy it from, local Midas?
Ian
Postby Ian » Mon Jan 22, 2007 2:21 pm
RudiGreyling wrote:I'd like to get one and compare it to an old MB one that I'll cut open to compare...where did you buy it from, local Midas?
This one was bought from Diesel Electric in Wynberg (near Sandton)
Postby Morph » Mon Jan 22, 2007 2:52 pm
Ian,
does this mean to have two fuel flow sensors? One on the inlet and one on the return line?
