Water temp drop
Sad-Ham
Water temp drop
Postby Sad-Ham » Tue Sep 13, 2011 3:43 pm
I noticed on saturday when I got back from a flight that if I switched off my left mag the needle on the water gauge dropped around 10 deg. I switched it back on and switched off the right mag , needle satyed exactly where it was. I have a blue top 582.
Anyone got any idea what could cause this?
Aquilla II ZU-DJS
Wingfield - 124.8
Re: Water temp drop
Postby Morph » Wed Sep 14, 2011 12:15 pm
Was it an instant drop, i.e. flick the switch and the needle drops or was it as a result of cooling down?
Sad-Ham
Re: Water temp drop
Postby Sad-Ham » Wed Sep 14, 2011 12:26 pm
Instant drop...... switch mag off and it instantly drops about 10 degrees , switch mag back on and it goes back up again
Aquilla II ZU-DJS
Wingfield - 124.8
Re: Water temp drop
Postby Morph » Thu Sep 15, 2011 8:42 am
That is definately electrical
Duck Rogers
Re: Water temp drop
Postby Duck Rogers » Thu Sep 15, 2011 9:17 pm
Who's Morph..? :shock: :shock:
Re: Water temp drop
Postby John Boucher » Fri Sep 16, 2011 11:53 am
Mooooooooorph....... welcome back! (^^) (^^) (^^)
V
Re: Water temp drop
Postby V » Sat Sep 24, 2011 8:14 pm
Hi Sad-Ham, as Morph says, if the drop is instant and your water temperature gauge is electrical, then the problem is electric. Water can't change temperature that quick. Often, electrical problems like this have something to do with the grounding. The mag switches ground the ignition, so that's another pointer in the same direction. As a first step I would check the gauge's connection to the ground. Second, the engine's ground.
Hope you come right.
Cheers,
V.
Sad-Ham
Re: Water temp drop
Postby Sad-Ham » Mon Oct 10, 2011 9:02 am
Thanks to all for the advice...... the problem was electrical. Re-grounded the guage and the problem was solved.
Aquilla II ZU-DJS
Wingfield - 124.8
