From Avcom
http://www.avcom.co.za/phpBB3/viewtopic.php?f=1&t=61412
Good news but also worrying if some suggest that motors are not getting to TBO on gyro's
Paul
TBO up to 2000 hours on 914
- Jabbanaught
Autogyro - Calidus ZU- ???
Magni M22 - ZU EGA
Magni M22 - ZU EGA
- THI
Re: TBO up to 2000 hours on 914
Well...lets prove them wrong!
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
ZU-CML
- FO Gyro
- Top Gun
I read through the Rotax document very quickly. If I read it right, it appears that to get an engine that is currently on a TBO of 1200 to 2000 requires replacement of the crankcase.
How much is a new crankcase, and is it worth it?
Glenn Poley
Moderator
ex ZU-AWE Windlass Trike
ex ZU-AOA VPM M16 Gyro
ex ZU-BPU Sycamore Gyro
ex ZU-GJP MT-03 Gyro
ex ZU-NPC RV9A
ZU-RJR Magni M24 Orion Gyro
Moderator
ex ZU-NPC RV9A
Why would that be?
- FO Gyro
- Top Gun
Again, if I read it correctly, only the last few 914's produced have an automatic TBO of 2000hrs. 914's that are more than a couple of years old require work to be done on them for the TBO to apply.
The mods required for TBO to 2000 hrs I read are as follows:
REPLACEMENT OF CRANKCASE:
Any 914 UL up to and including S/N 4.419.315 is affected. My MT-03 is 3 yrs old, and just escapes needing a new crankcase thank goodness.
PLUG SCREW OF OIL PUMP:
Any 914 UL up to and including S/N: 6.773.778 requires replacement of the plug screw and the pressure spring.
ELECTRIC FUEL PUMP:
The electric fuel pumps must be replaced on all engines at 1000hrs.
The requirements for the 914F (certified version) are similar, but the serial numbers affected are different.
ELECTRIC FUEL PUMP:
Glenn Poley
Moderator
ex ZU-NPC RV9A
Moderator
ex ZU-NPC RV9A
