Conversion from weight shift to 3 axis and vice versa
Barn owl
Postby Barn owl » Mon Apr 12, 2010 11:52 am
What is required to convert from weight shift to 3 axis?
And the other way round?
andrepieterse
Re: Conversion from weight shift to 3 axis and vice versa
Postby andrepieterse » Mon Apr 12, 2010 7:19 pm
Check on the www.raasa.co.za website. Click on the "Pilot Requirements" heading, then click on "Conversions Between Categories". You'l find a very helpfull table that would answer most questions.
Andre
WillemG
Postby WillemG » Mon Apr 26, 2010 9:05 am
Hi All.
The requirements have changed from those on the website, please consult the regulations regularly for the most up to date requirements.
Willem Grobbelaar
RAASA
011 827 9330
hugo
Postby hugo » Tue Jun 15, 2010 5:11 pm
hi guys
I did a conversion from weight shift to 3 axis in a jabbi at rhino park collected my lisence today vhpy vhpy vhpy
Exams: You need to write Aircraft technical and general LSA (RAASA EXAM) and Principles of flight LSA, very easy exams just study Jim Davies's PPL book and study the Swales mock exams LSA ## ##
Hours: Law says you must do 35hrs but you can get up to 15hrs credit so that basically leaves you with 20hrs of witch a minumum must be 10 hrs SOLO
(I did mine in 22.5 hrs)
Do a flight test and bobs your uncle ## ## ## (Well thats what i did)
P.S Make sure u get a NPL LSA Student lisence before you go SOLO
Hope that might clear things up a bit. ## ##
Aquilla ZU-CCM
Jabbi
Pat Two
Postby Pat Two » Thu Jun 17, 2010 6:07 pm
Geluk Hugo! Die Jabi's vlieg darem baie lekker.
Jaco P.
