Addis 25L Fuel containers?
- pietmeyer
I bought two of the red 25l Addis jerry cans a few months ago but the caps started cracking not long after I started using them. I phoned Addis and they sent replacement caps and I was informed that they had a product issue as these were imported from China or somewhere. The new yellow replacement caps are stronger but the inside rubber started melting as soon as it cam into contact with petrol. Seems like they are not made for petrol. Anybody had the same problems yet? I have 10 new caps but looks like I will be using 1 a week.
Piet Meyer
Jabi J400 ZU-DUU (Wonderboom)
Re: Addis 25L Fuel containers?
Yes. I bought one two months ago and the top of the filler cap broke off. When I went to fill at the service station I found it broken no knocks or other apparent cause. Do you have Addis' phone number?
- pietmeyer
Addis can be contacted at the following numbers
USABCO
Johannesburg: (011) 330-8888
Capetown: (021) 917-2000
email: info@usabco.co.za
USABCO
Piet Meyer
I've got the same problem. It is a damn difficult job getting fuel containers that dont leak and make your car smell of petrol. I started out with the white containers (school insisted so they could check that fuel had been mixed with oil) - They cracked after 2 years. Bought the addis cans - both caps cracked. The steel jerry cans does seem a better buy but they only take 20 liters which makes pre-mixing inconvenient. Oil injection is looking more and more attractive.....
I anybody has found a solution please post it here
One word of advice. Always try to use see through containers. You can then see sediment or any bits that gather at the bottom of the container.
Cheers,
Cheers,
Should be able to make your own. We use pressure to refill.... Just a thought...
- Trikenut
My dad has a 25L addias container that he uses for fuel for our boat. We have had said container for 3 years plus and have never experianced this!
We also use unleaded!
Maybe a manufacturing fault in the batch you bought??
"Beware 16 year old here"
- Low Level
Tip - never let the pump attendant close your Addis can.
I bought two, two and a half years ago, and still use both of them with the original caps. Do not overtighten the caps, then it seems to last longer. The one's seal has broken but the caps are still intact.
ZU-CFW
ZU-CFW
I bought the steel jerry's as my hanagr is moer hot and the plastic ones blow up (not with a bang just get bigger). Only hold 20l, slightly more expensive, but they work well and don't break or leak. That said I used a 25l plastic one for the cubby and the lid was broken in month... Seems over tightening (to prevent leak in car) is a problem. I have been told if you put plastic over and then just finger tighten it also does the trick and the lid lasts much longer.....
PS
We get what looks like old 25l fruit juice white ones here from Midas for R50 and they work very well...
PS
- James Bentley
- Almost a pilot
Try containers made by Mega Plastics, not too sure if they are still around??
I have one which has seen regular use now for a long time (15 years)
Its still perfect and the cap has never given a problem, the secret as RV4ker says is not to over tighten
Airfield EVA'S FIELD
Home EVA'S FIELD
Work Pietermaritzburg
Home EVA'S FIELD
- BOATCH
I put plastic over the lid and after a day the plastic melted away so the DKW had 25 liters of feul cause i would not use that feul in my aircraft,and yes i also have the feulcap problem on the red feul cont.
Yip my cap cracked as well only used 3 times.
Must get airborne again
Andre'
Flying Below power lines on a DSX650
Too much power is just enough
Andre'
Not cracked yet - but does not seal properly - not even when you put the funnel magafda through the lid.
- Stephan van Tonder
Yup one of my pet hates. I also bought about 5 ot those addis containers for water on 4x4 trips. First time I used one it started pissing water before I got to PTA and the lid cracked in 10 minutes. Cost me buying other containers en-route and then sit with empty containers for a twoo week trip - if they weren't so expensive I would have thrown them away. SO I sit with 5 of those unusable. Thanks for those contact details - sure to give them a shout. All I wanted was a solid cap instead of the one that can take the spout.
As for fuel for the plane - I use one of those 25l white containers - and then we use a rotary hand pump to decant it to the airplane. Something like this - available at most Mica or midas spares shops. http://www.handpump.cn/english/Hand%20Rotary%20Pump.htm
