582 Red Top
Mike Cordeiro
582 Red Top
Postby Mike Cordeiro » Tue Apr 01, 2008 10:18 am
I finally got My 582 Red top with closed loop fuel injection.
I`ll post some photos soon....
Rudix
Re: 582 Red Top
Postby Rudix » Tue Apr 01, 2008 10:29 am
Mike Cordeiro wrote:I finally got My 582 Red top with closed loop fuel injection.
Cool ! The one with the 10000h crank ??
Mike Cordeiro
Postby Mike Cordeiro » Tue Apr 01, 2008 10:39 am
Acording to the manual it looks like it needs to be inspected at 600Hrs and replaced at 1200Hrs.
Re: 582 Red Top
Postby Morph » Tue Apr 01, 2008 11:48 am
Rudix wrote:Cool ! The one with the 10000h crank ??
Yes, it should say, crank replacement on destruction only
Petrodactyl
Postby Petrodactyl » Tue Apr 01, 2008 3:42 pm
Does the closed loop fuel injection recycle the fuel already used, thus improving endurance indefinitely?
Christian Carver
Go Fly a Trike!
ZU-BBU
Mike Cordeiro
Postby Mike Cordeiro » Tue Apr 01, 2008 4:53 pm
Closed-loop system programs the fuel injection system while you fly
•No wrenching, no dyno tuning, no need for constant adjustments – just start up and go .
•Increases horsepower and torque by as much as 20% along with a decrease in emissions and fuel consumption
•Fully automatic dynamic tuning with a Rotax Platinum II oxygen sensor
•Coordinates the factory ECU calibration, updated calibration and race-tuned calibrations
•Coordinates the factory ignition and fuel tables by utilizing the factory preset altitude sensor
•Operates using the Alpha rpm and throttle position detector
•Over-molded, sealed, surface-mounted circuit board design
•Installs by connecting just six wires and the O2 sensor
•Made in Austria
Postby Boet » Tue Apr 01, 2008 7:54 pm
Hallo Mike,
Tell a bit more: What Hosses? At what rpm??What geabox? Is it an a/c engine. Is there still a note on the box telling you taht this is a kak engine that can quit on you any moment..... :roll:
priester
Postby priester » Tue Apr 01, 2008 8:06 pm
Superboet ..... die datum ......
Postby Boet » Tue Apr 01, 2008 8:19 pm
Jaaaaaa, Oom Priester. DIE f`n datum. :oops: @de keer vanaand. Strooi met julle ouens, ek ga nou slaap....
Byron
Postby Byron » Tue Apr 01, 2008 8:51 pm
If you don't mind me asking ..... what did this exercise set you back Mike?
Mike Cordeiro
Postby Mike Cordeiro » Wed Apr 02, 2008 11:07 am
priester wrote:Superboet ..... die datum ......
:lol: :lol: :lol:
Postby John Boucher » Wed Apr 02, 2008 12:51 pm
Starting to look like a JETSKI forum..... if only they would use some of the awesome solutions they have in JETSKI's and offer it to AVIATION!
But ok, Part 24 still not resolved, ROTAX issues have left an aftertaste in our mouths methinks!
If not mistaken, the REDTOP comes off a 583 and is used in SKIDOOS. Pushes some 100HP's and is in essence the same as a 582!
IF ONLY SIR, IT WAS NOT APRIL 1!
Byron
Postby Byron » Thu Apr 03, 2008 9:41 pm
....... can't believe I fell for that one! :oops:
Postby John Boucher » Fri Apr 04, 2008 8:54 am
Byron
In essence, not so far fetched info by Mike.... actually sort of factual!
Snippets of technical specs from various Rotax / Seadoo / Skidoo confirms this!
Could actually be an awesome aerie engine!
Mike Cordeiro
Postby Mike Cordeiro » Fri Apr 04, 2008 9:43 am
Byron wrote:....... can't believe I fell for that one! :oops:
Don,t feel bad, at least you were a good sports.
In the U.S. and the E.U. 2 stroke engines have been banned due to stringent emission regulations. I think that 582 production will soon cease.
The good news is that Rotax will be underpressure to replace the 582 with an afordable 4 stoke.
If you look at all the new Jet-ski`s ,( As Bad-nav mentioned ) they all now fitted with 4 stroke engines with superchargers or turbo chargers, fuel inj. and so on.Maybe that,s an indication of what,s to come for the Microlighting industry ??
