Gloves
THI
Gloves
Postby THI » Wed Apr 01, 2009 1:33 pm
Now that winter is on its way (all most), what kind of gloves can I use to prevent frosty fingers while flying? :?:
Thinus Enslin
Potchefstroom (FAPS)
ZU-CML
Would love a RV10 though...
Lesser_spotted_owl
Re: Gloves
Postby Lesser_spotted_owl » Wed Apr 01, 2009 1:40 pm
Hi THI,
I have a nice pair from the Outdoor warehouse,they just make frequency changes tricky. otherwise we have a pair of mitts on the trike, made by Solo wings, they work well too, nice warm fingers
( the only other problem is keeping the feet warm )
ZU-CRC Cobra
Tracer
Re: Gloves
Postby Tracer » Wed Apr 01, 2009 2:26 pm
I wear Mares diving boots, whenever I fly. They are comfortable, great feeling on the throttle and they are warm, have never had a problem with feet being cold.
THI
Re: Gloves
Postby THI » Wed Apr 01, 2009 2:28 pm
Lesser_spotted_owl wrote:Hi THI,
Hi Lesser_spotted_owl,
The gloves that your refer to from Outdoor Warehouse, are they the normal leather gloves?
Thinus Enslin
ZU-CML
Bugwar
Re: Gloves
Postby Bugwar » Wed Apr 01, 2009 2:32 pm
Also got a pair from Outdoor Warehouse. Works very well. R100.00. The make is called 360deg. windproof outer and warm , removable inner. Come in different "weights" depending on the amount of insulation required. Look at my avatar. It is the grey glove in the pic.
ZU-EHG - Raptor
Vulture Squadron videos
THI
Re: Gloves
Postby THI » Wed Apr 01, 2009 2:40 pm
paul.dekock wrote:Also got a pair from Outdoor Warehouse. Works very well. R100.00. The make is called 360deg. windproof outer and warm , removable inner. Come in different "weights" depending on the amount of insulation required. Look at my avatar. It is the grey glove in the pic.
Hi Paul,
Het jy die "Windblock Gloves"?
Thinus Enslin
ZU-CML
Lesser_spotted_owl
Re: Gloves
Postby Lesser_spotted_owl » Wed Apr 01, 2009 3:06 pm
Hi THI,
They are not leather, they are the same as the ones in Paul's avatar, really good.
For the feet, a pair of running socks under some hiking socks and a pair of skater takkies, they work pretty well
ZU-CRC Cobra
Bugwar
Re: Gloves
Postby Bugwar » Wed Apr 01, 2009 3:13 pm
Dink hulle noem dit "wind block" ja.
ZU-EHG - Raptor
THI
Re: Gloves
Postby THI » Wed Apr 01, 2009 3:19 pm
Thanks for all the info. I will be visiting an Outdoor Warehouse soon!
Thinus Enslin
ZU-CML
vernon11
Re: Gloves
Postby vernon11 » Wed Apr 01, 2009 8:36 pm
I have found the mitts on the bar to be the best. no interferance when having to change frequency. I used to use ski gloves which were not so bad. Mitts are for me the best, but then I fly at the coast. Not so cold here.
Fly safe.
Vernon.
Dre'man55
Re: Gloves
Postby Dre'man55 » Wed Apr 01, 2009 8:45 pm
African Grey has a set of gloves that have cut off fingers for when you need to work with the radio and a mitt section that pulls over the fingers when you are flying. I couldn't find a pair anywhere. They are perfect. What I eventually did was cut 3/4 of the way through the right index finger of my gloves just above the first knuckle, so when you need to push buttons you can expose your finger. When your finger is covered and you are holding the bar your whole hand is protected again.
Must get airborne again
Andre'
Flying Below power lines on a DSX650
Too much power is just enough
bluesmancoops
Re: Gloves
Postby bluesmancoops » Thu Apr 02, 2009 8:00 am
I just fly in a closed cockpit with no gloves (^^)
Mike Cooper
Arnulf
Re: Gloves
Postby Arnulf » Thu Apr 02, 2009 8:31 am
bluesmancoops wrote:I just fly in a closed cockpit with no gloves (^^)
Softie s071
mak
Re: Gloves
Postby mak » Thu Apr 02, 2009 8:34 am
My softness bought two leather gholf gloves that she uses in our open cockpit and it really works well, warm and nice tight fit to work radio buttons. You can also try cycling shops for their winter gloves. I have a pair, nice and warm, but unfortunately mine one size too big. Winter cycling tip for cold feet that also works for flying, put small plastic sandwich bags over your socks before putting on your shoes.
www.altairaviation.co.za
Nkwazi
Re: Gloves
Postby Nkwazi » Thu Apr 02, 2009 12:27 pm
Ag Shame :lol: :oops:
ZU-BFS Aquilla
ZU-SMC Cheetah
Benoni
Impukane Nkwazi
MISASA Treasurer
