Transporting a project?
justin.schoeman
Postby justin.schoeman » Thu Feb 12, 2009 9:25 pm
vhpy vhpy vhpy
My Raven airframe is ready! Now I just need to get it from George to Pretoria. Unfortunately I am under real pressure at work, and can't really take the time to drive to George and trailer it back.
What other options are there (that aren't ridiculously expensive!)? Any transport companies, furniture removals, even rail freight options?
Any advice appreciated!
Justin
AndyG
Re: Transporting a project?
Postby AndyG » Thu Feb 12, 2009 9:47 pm
Give me the weight and dimensions andI will see what I can do for you
justin.schoeman
Postby justin.schoeman » Thu Feb 12, 2009 9:59 pm
AndyG wrote:Give me the weight and dimensions andI will see what I can do for you
250kg. 6m x 2.5m x 2m (wings pack under the fuselage)
Thanks vhpy !
Justin
Postby RV4ker (RIP) » Thu Feb 12, 2009 10:24 pm
Try SAR. I sent a car down to FAGG cheaper than I could drive it. If you not in a hurry and it can be packed for you...
Offer cash incentive, maybe someone will go get it for you... :twisted: :twisted: :twisted: :twisted:
AndyG
Postby AndyG » Thu Feb 12, 2009 10:32 pm
Is it crated or not?
Let me know
justin.schoeman
Postby justin.schoeman » Thu Feb 12, 2009 10:38 pm
AndyG wrote:Is it crated or not?
Let me know
Not crated...
justin.schoeman
Postby justin.schoeman » Thu Feb 12, 2009 10:39 pm
RV4ker wrote:Try SAR. I sent a car down to FAGG cheaper than I could drive it. If you not in a hurry and it can be packed for you...
Do you have any contact details. I have sent a couple of emails via their on-line enquiries, but got no response...
Postby RV4ker (RIP) » Thu Feb 12, 2009 10:46 pm
One of my staff used to work for them. He organised it all for me. He now in Oz, so no contacts sorry. :oops: :oops: :oops: :oops:
Grumpy
Postby Grumpy » Fri Feb 13, 2009 10:56 am
Bayliner needs to go up to JHB somewhere to fetch his trike, and I think he will be going with an empty trailer. maybe if you plane is crated he can do a detour and share expenses.
Bayliner
Postby Bayliner » Fri Feb 13, 2009 11:35 am
I am willing to help. Tomorrow I'm going to see if I can introduce myself to Morph and some others at Morningstar to discuss renting/hiring a trailer. My plane is a trike and I assume that I only need to fold up the wing. I will be driving an Isuzu double cab. At the moment the canopy and tailgate has been removed for respraying. I will get this back on Thursday next week. I mention this in case you want my help and I would need to know if I should fit the canopy or not. Sharing costs can be dealt with later. Grumpy, thanks. Maybe you should change your name to Happy!
justin.schoeman
Postby justin.schoeman » Fri Feb 13, 2009 11:51 am
:idea: PM Sent! vhpy
Bayliner
Postby Bayliner » Fri Feb 13, 2009 12:02 pm
Got it. Will e-mail you shortly. I will be staying with a friend in Pretoria which should make things easier.
justin.schoeman
Postby justin.schoeman » Thu Feb 19, 2009 6:35 pm
Looks like Bayliner is taking a trike trailer up...
Anybody know if it would be practical to put a 3-axis on a trike trailer? Wheel track is 74" (1.87m).
Maybe it is possible to secure the forward fuselage (probably similar wheel positioning to a trike?) and wings on the trailer, and then hire a set of tail light extensions to place on the tail of the aircraft.
The wings are each 2.4m long, so should fit comfortably on the trailer. The fuselage is 6m long. The big things that could probably go worng: 1) wheel positions wrong; and 2) engine sticks out too far beyond the front wheel (which is typically the furthest forward point on a trike).
Anybody know if this can work?
Thanks,
Justin
Grumpy
Postby Grumpy » Fri Feb 20, 2009 10:27 am
Justin, I'm not a transport guru, but I think it would be easy to overcome the wheel positioning. A flatbed config trailer and you're ok. The problem is the fuselage at 6m on a 3m trailer is your big problem. At 6m length you're talking 'furniture removal' size transport.
Stephan van Tonder
Postby Stephan van Tonder » Fri Feb 20, 2009 10:55 am
Car trailer will accomodate that.....
