Prop confusion.
Prop confusion.
To minimize confusion when asking for a prop, or tying to sell one: ALLWAYS think of the prop as if looking at it in the direction of travel. IE, from the rear, as if the cockpit IS there..... jaaaa kooos,... even in a pusher configuration. SO: A Rotax 503/ 582 in a TRIKE will take a RHT (Right Hand Tractor, Koos) BUT in a Koala or a Bushbaby it will use a LHT. ......that is UNLESS it has a belt-drive system, then the opposite is of relevance. With fixed blade props, state the daiameter and pitch, normally indicated in inches, ie. 72X52,of the prop you want or want to sell, otherwise either confusion or "slow smile" will result.
- Duck Rogers
Re: Prop confusion.
Dankie Boetie...........I've also posted this before, to no avail
Needs to be made a "sticky" somewhere.........
Re: Prop confusion.
Ek wil n propellor verkoop wat op n aeroplane was en hy was voor op en hy het gedraai.................................
ek moet nou hardloop....
- Duck Rogers
Re: Prop confusion.
........en gedraai en gedraai en gedraai tot hy AFGEDRAAI het! Dis nog in redelike goeie toestandAerosan wrote:Ek wil n propellor verkoop wat op n aeroplane was en hy was voor op en hy het gedraai.................................![]()
ek moet nou hardloop....![]()
Kort net 'n bietjie patching hier en daar en hy werk weer
Re: Prop confusion.
Links-om gedraai of regs-om gedraai ? Prys verskil ?........en gedraai en gedraai en gedraai
Roel Jansen
ZU-IAR powered by BMW 1200
- Duck Rogers
Re: Prop confusion.
Regsom gedraai tot dit afgekom het. Linkerkant is nog goed. Klein prys verskilletjie..........regterkant bietjie ge-damage. geen prysverskil nie........jy kry discount vir die regterkant
Re: Prop confusion.
yeah and don't be like me many years ago, install it back to front
You tend to rev very lekker but go nowhere
Re: Prop confusion.
Jaaaa, ons maak maar almal ons mistykies. Ek het die 2 brekers van errouplyns by die AP seminaar ontmoet. Was lekker om nuwe gesigte by die name te sit!!
Re: Prop confusion.
Ja Oom Boet
Brekers is ons brekers hier van die Wesrand af en als
dit was nogals nice om n gesig by n paar van die name te sit
Sanna
Sanna
