Most popular Rotax 2 stroke prop bolt pattern?
justin.schoeman
Postby justin.schoeman » Sat Jan 10, 2009 11:34 am
I am ordering my prop (IvoProp, in flight adjustable), and reduction drive (Niel Terblanche). I can order both with specific bolt patterns.
Since I am not 100% sure that the VW will work well in the airframe, I want to make sure that the prop is as re-sellable as possible. The VW redrive give left hand prop rotation (the same as a Rotax 2-stroke). Since this is also probably the most common microlight engine, it makes sense to specify a bolt pattern that matches.
The problem is, it seems that at least 2 different bolt patterns are used. Can anybody tell me which is the most common? Or are there any other suggestions?
Thanks!
Justin
Re: Most popular Rotax 2 stroke prop bolt pattern?
Postby Boet » Sat Jan 10, 2009 12:12 pm
25mm centre boss, 6 holes X 8mm and 100mm centre to centre.
justin.schoeman
Postby justin.schoeman » Mon Jan 12, 2009 9:44 am
Thanks Boet. Rotax bolt patterns are very confusing. I would have thought they would standardise between all their products!
justin.schoeman
Postby justin.schoeman » Mon Jan 12, 2009 10:10 am
Just got the bolt pattern diagrams from Aviation Engines. It seems the C and E gearboxes have holes for both 75mm PCD and 100mm PCD - is this correct?
Wouldn't it be better to use 75mm PCD then, as this seems to be compatible with just about every Rotax 2 stroke?
Thanks,
Justin
Postby Boet » Mon Jan 12, 2009 7:57 pm
100mm better.....
justin.schoeman
Postby justin.schoeman » Mon Jan 12, 2009 8:14 pm
Thanks!
