Question to all science boffins
Can anybody help me with this scientific question:
1) Assume that if you attach the vacuum tube of a Venturi tube to a closed chamber, you find that at a specific airflow (x) the drop in pressure within the chamber is y.
2) Now assume that you attach two independent but identical Venturi tubes both subject to airflow x, to the same closed chamber.
Question: Will the drop in pressure in the closed chamber with two Venturi tubes attached to it, be y or 2y?
ZS-VFZ
Re: Question to all science boffins
It will be 'y'.
Since air moves from a region of high pressure, to a region of low pressure, adding an identical venturi, producing the same pressure will result in no nett air flow, so the pressure will stay the same.
Korrek.justin.schoeman wrote:It will be 'y'.
I know I'm probably sounding stupid to all the scientists out there, but here is what I can't figure out:
If you are emptying a glass of water with two syringes, it will take half as long as if you tried emptying the glass with one syringe. Two syringes = twice the suction, therefore why should two venturi tubes not suck double the amount of air from the closed chamber and thus produce a combined suction force of 2y?
ZS-VFZ
- Rudix
- The Boss
No, you will get double the "VOLUME" of suction but the "STRENGTH" will still be y.salem wrote:I know I'm probably sounding stupid to all the scientists out there, but here is what I can't figure out:
You cannot add the 2 suction forces, the actual suction would be the average of the 2 (if they "suck" the same volume")
My question is why?salem wrote:Will the drop in pressure in the closed chamber with two Venturi tubes attached to it, be y or 2y?
Because both venturis produce an equal amount of suction.
With one venturi the drop in pressure will take place in x time
and with two venturies in half the time
So we have a reduction in time but not an additional reduction in pressure.
Take a bucket fill it with water drill a hole in the full bucket
measaure the time it takes to empty the water.
now repeat same experiment with two identical holes drilled in the same bucket, bucket should empty in half the time.
You cant empty more water out of the bucket because there is no more (unless you add more).Volume of bucket is fixed.
So the same for closed cylinder with attached venturi/venturies.
Kind regards,
Gunter Rostek
Kind regards,
Gunter Rostek
The answer is also why (y)Morph wrote:My question is why?salem wrote:Will the drop in pressure in the closed chamber with two Venturi tubes attached to it, be y or 2y?
ZS-VFZ
Now take the same situation, but the two venturis have different pressures, 'x' and 'y'. What will the resultant pressure be in the closed chamber?
HINT: This is a trick question!
No, I mean why are you asking this question.
Are you looking at balancing your carbs etc?
It should be (x + y)/2justin.schoeman wrote:Now take the same situation, but the two venturis have different pressures, 'x' and 'y'. What will the resultant pressure be in the closed chamber?
ZS-VFZ
Nope. once the pressure differs, air will flow from the higher pressure pitot to the lower pressure pitot. The system is now a hydro-dynamic system, rather than hydro-static, so different rules apply. In all likelyhood, the pressure will be slightly less than (x+y)/2, but this depends on shape, size and interfaces of all the pipes and chambers.salem wrote:It should be (x + y)/2justin.schoeman wrote:Now take the same situation, but the two venturis have different pressures, 'x' and 'y'. What will the resultant pressure be in the closed chamber?
Physics is a b*tch...
Hi MorphMorph wrote:No, I mean why are you asking this question.
It's for a project that I have in mind. I might pop in at Morningstar and discuss it with you on Saturday.
ZS-VFZ
Cool, I'll be there all morning. Might be in the air for some of the time. Look for my burgandy Corsa Bakkie
