Exhaust mountings
wiskeyfoxtrot
Exhaust mountings
Postby wiskeyfoxtrot » Fri Dec 12, 2008 7:54 am
Can anybody help,
I have a 582 and the exhaust mountings keep breaking!!!!!
I have tried the types you get at Midas and they are the biggest rubbish ever!!!!
Last rubber lasted all of 2 minutes before tearing in half.
The mounting rubber is round ( the size of an old 20C piece with a threaded pin on each side, 1.25 pitch thread.
The original rubber bushes lasted for ages ( good quality ) 110 hours !!!!!
Can anybody help with supplier who has good quality ?????????
the exhaust hangs underneath the motor & if these rubbers break off you stand to mince the prop
& exhaust canister. I have a safety cable attached but NOT good enough.
Aeroprakt A22 Foxbat
ZU - DYE
Sport Cruiser
ZU - LSA
Stephan van Tonder
Re: Exhaust mountings
Postby Stephan van Tonder » Fri Dec 12, 2008 8:15 am
http://www.cometaviationsupplies.co.za/default.asp
http://www.aviationengines.co.za/
Same company and is the importer of ratax engines and parts. Sit down before asking for a price of anything there though.
Carel
Survived first engine out
Postby Carel » Fri Dec 12, 2008 11:54 am
Closest exhaust shop that sell Bosal exhaust systems. Will find what you need at a reasonable price and they last long enough to give you value for money.
Postby Boet » Fri Dec 12, 2008 8:48 pm
Nope, I have much better and faaaar cheaper selution for this problem.......Have been making these for a long time, and not a single one have ever broken on me.
wiskeyfoxtrot
Postby wiskeyfoxtrot » Mon Dec 15, 2008 8:28 am
Thanks guys for your input,
Boet I like your idea, and will give it a try !
Thanks a lot.
vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy vhpy
ZU - DYE
Sport Cruiser
ZU - LSA
Postby Boet » Mon Dec 15, 2008 12:34 pm
You`re welcome. I use 25mm id radiator hose. vhpy
Grumpy
Postby Grumpy » Mon Dec 15, 2008 1:50 pm
Boet wrote:You`re welcome. I use 25mm id radiator hose. vhpy
Eish Boet, is dit 'n Boer maak n plan' of 'Backyard Mechanic' (^^)
Postby Boet » Tue Dec 16, 2008 10:55 am
Nee Grumpy, dis Boer maak n plan. Ek het gatvol geraak om daai larney rubbertjies te koop vir +-R80 stuk, net om hulle na elke paar uur te moet vervang. Hier is baie stukkies "offcut" 25mm radiator pyp, gevolglik kos die hangertjies my nie baie nie. As jy dit nog stewiger wil he, maak die pyp gedeelte vol poly-urethane sealer. vhpy vhpy
