What are the criteria for classification under microlight or the new recreational licence, wrt weight etc?
Bad Nav wrote:So name me a few 260kg and less 3-axis aeries please....
I also have it that there is to be differentiation between weight shift & 3-axis where presently MLP is MLP and you only had to do a conversion....
Bad Nav wrote:So name me a few 260kg and less 3-axis aeries please......
There is almost no weight difference between 503 and 582. The 912 engine is about 30kg heavier. So, if you have a very light frame, you can still have a mpl 3 axis.RV4ker wrote:Cubby, Bush Baby with 582, Bantam, Small Jabi (SP?), almost all the 503 Rattex jobs....
