MGL CHT probes for 912s
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Thu Nov 27, 2008 9:46 am
Hi guys, has anybody fitted MGL's CHT probes on a 912s engine? I bought a set and would like to fit it but it doesnt look as if it will fit! the spark plug is recesed and there is no way that i can get the probe in. MGL says you have to file down the probe and the reces on the engine block to fit the probe? any advise?
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
Re: MGL CHT probes for 912s
Postby Morph » Thu Nov 27, 2008 11:27 am
The 912 has CHT probes already installed, on the front left head and the back right head.
When you set up the MGL unit you need to specify it is for a 912, because the probe type is different to the standard MGL unit. YOu need to set the guage to Standard NTC
CHT Probe.JPG (82.3 KiB) Viewed 1882 times
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Thu Nov 27, 2008 11:48 am
hi greg, i've used the standard / built in probe but Reinier @ mgl said that you can not use the std / built in tyoe probe with the mgl unit (E3 engine monitor)? but i wil have another look at the setup on the E3.
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
Postby Morph » Thu Nov 27, 2008 2:21 pm
Oh OK, I have the Stratomaster XL and that does infact support the 912 type probes
Stephan van Tonder
Postby Stephan van Tonder » Thu Nov 27, 2008 3:36 pm
There are different size probes from MGL. So just get the right size and bolt it to the same place as where the original probe sits. You don't HAVE to go under the spark plug.
Postby Morph » Thu Nov 27, 2008 4:40 pm
good idea, :idea:
Yes the original probe screws out, and you don't loose any water from the hole.
Stephan van Tonder
Postby Stephan van Tonder » Fri Nov 28, 2008 10:13 am
The mgl probe is a round ring that bolts under a bolt like a washer. So you can just unscrew the current probe - put the MGL probe under it like a washer and screw the original back in. the smallest size is a 10mm.
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Tue Dec 02, 2008 4:16 pm
i did this yesterday and will test this afternoon. thanks for the idea.
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Wed Dec 03, 2008 3:51 pm
works like a charm.
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
Stephan van Tonder
Postby Stephan van Tonder » Wed Dec 03, 2008 7:17 pm
!!!! no worries. Glad I could help.
