Just curious. I am purchasing a cheetah with 80hp rotax. If cruise speed is 90mph at sea level MAUW what could i expect the TAS to be at say 5000'
flybynite wrote:Hi Allan
Be very wary - for every positive there is a negative -if you start increasing the speed you will loose lift! Your Cheetah is only the 80 hp version - if it had the 912 uls you could have made a plan to get a bit of both worlds. (Remember the short grass strip that you and your boet wants to fly from?)![]()
Larry
