this is from Johann Froneman
HI MIKE COULD YOU PLEASE PUT THIS ON THE MICROLIGHTERS FORUM.THE FREQ. AT SALDANHA IS BACK TO NORMAL AND WE WILL NOW HAVE IT REGISTERED AND PUBLISHED AS A PERMANENT FREQ.
THE FOLLOWING PROCEDURE WILL REMAIN AS FOLLOWED, ENTERING LANGEBAAN CTR YOU GO TO 122.5 REQUEST SALDANHA AND THEY WILL CLEAR YOU UP TO OR OVERHEAD SALDANHA, WHERE YOU WILL THEN CALL ON 122.7, LEAVING THE SALDANHA CIRCUIT THE SAME APPLIES GO TO 122.5 AND TELL THEM YOU LEAVING SALDANHA FOR WHAT EVER. OUR CIRCUIT IS 1.5NM RADIUS UP TO 1500FT AGL.
THANK YOU
saldanha frequency final
- bluesmancoops
Mike Cooper
