Zodiac HD/Raven stats, please!
justin.schoeman
Postby justin.schoeman » Mon Oct 27, 2008 2:37 pm
OK, I have finally done it, and placed an order for a new Raven airframe vhpy vhpy vhpy .
Now the fun part begins - choosing the engine. I am aiming to make this sucker as fast as humanly possible, but still keep it cheap. With any luck, I will get away with a 2200 Jabiru engine (current record is 120ktas @ 8000').
What I would like to do is gather stats on flying 601HDs/Ravens, and see if I can calculate what the actual drag is, what the ideal prop will be, and what performance can be expected.
If anybody wants to help in this effort (and you happen to own a 601/Raven ;-) ), I would appreciate any/all of the following information:
1) basic details:
- engine
- prop diameter
- prop pitch
- any airframe mods
2) static rpm:
- (density) altitude
- rpm
3) WOT level speed:
- rpm
- speed
4) WOT climb performance (at different speeds, if possible)
- rpm
- speed
- climb rate
Thanks in advance!
Justin
James Bentley
Re: Zodiac HD/Raven stats, please!
Postby James Bentley » Mon Oct 27, 2008 2:54 pm
Congratulations Justin (^^) (^^) (^^) (^^)
I do not have any data yet but will keep you posted on the success of my 2200 in the Raven
will speak to Pottie who has the other Raven in my hangar
he records everything during all of his flights and can provide a wealth of information
his is fitted with a 912s and the performance is amazing given our field elevation of 3400ft
Pottie is also building another Raven, this time a tail dragger. His plan is to build a really light & simple aircraft which will have the Jab engine installed !!!! !!!!
Let us know how you get on
cheers and regards
James
Airfield EVA'S FIELD
Home EVA'S FIELD
Work Pietermaritzburg
bluesmancoops
Postby bluesmancoops » Mon Oct 27, 2008 4:29 pm
It would be good to cantact Johann Froneman as he has built a number of these planes 082 457 9509
Mike Cooper
swiftprop
Postby swiftprop » Wed Nov 19, 2008 7:38 pm
Congratulations Justin for choosing a Raven! If you like I can e-mail you all the correspondence between myself and Gunter Rosetek re the Raven. All very positive. You can pm me your e-mail if you like
Flying regards
Andre
DB Warren
Slow starter
Postby DB Warren » Sun Dec 14, 2008 3:39 pm
Hi Justin I have a Raven 601. If you give me your landline number we can have a chat. Mine is 033 2122524 home and Cell 0824580050. Cheers DB Warren
John Young
Postby John Young » Sun Dec 14, 2008 3:51 pm
DB Warren wrote:Cheers DB Warren
Hi DB,
Welcome. !!!!
Nice seeing you at Light Flight today. Remember, next time you land without meat for the braai ## ## ##
John ZU-sEXY
swiftprop
Postby swiftprop » Tue Dec 16, 2008 6:52 pm
Hi Justin
Would you mind going through your basic thought process in choosing the Raven on the forum Other than just cost cost and cost! Also it will be nice if you can share the CAA process you are following.
Flying regards
Andre
