Props on Jabiru engines
James Bentley
Postby James Bentley » Mon Oct 20, 2008 2:27 pm
Has anybody out there tried a Sensenich propellor on the Jabiru 2200 (85hp) engine?
I am building a Zenair 601HD with the Jab and would appreciate any info on prop installations for best performance :?:
GT also produce a prop for this engine and would be interested to hear from owners who could compare with the original Jab supplied one
Airfield EVA'S FIELD
Home EVA'S FIELD
Work Pietermaritzburg
TouchNgo
Re: Props on Jabiru engines
Postby TouchNgo » Mon Oct 20, 2008 2:36 pm
hi James,
if I am not mistaken you should talk to "Captain Biggles" on this forum.
I believe he fitted one to a jab powered Skyranger.
oh ate two eight 5 seven nine for oh 5
greg
justin.schoeman
Postby justin.schoeman » Mon Oct 20, 2008 2:54 pm
How about sensenich's recommendations:
http://www.sensenichprop.com/sen_html/p ... -adv-4.pdf
The prop selection is VERY airframe dependant, so you should consider posting your question on one of the zenith builder's lists.
James Bentley
Postby James Bentley » Mon Oct 20, 2008 2:57 pm
Thanks for the info so far vhpy vhpy
Will call Captain Biggles !!!!
James
Home EVA'S FIELD
Rudix
Postby Rudix » Mon Oct 20, 2008 7:27 pm
Hi James, hope you are well !
I have flown my Jabiru powered Shadow with a Arplast Echo prop and a Warp Drive, both 3 blades and cut down. The Warp appears to be the best, set at about 16 deg pitch. The pitch is a bit coarse for climb but great for cruise.
I am watching your progress with great interest as I must still make a final decision as to what is going to be bolted on here....
vhpy vhpy
James Bentley
Postby James Bentley » Tue Oct 21, 2008 8:45 am
Hi Rudi
I know the Jabiru will work well, its finding the correct pitch for the prop if we install a Sensenich/GT which is fixed.
There are two listed for the Zenairs, 40" or 42"
Hope to be able to make the correct choice upfront as the props are rather expensive at today's rates.
Warp Drive is another option...
The more info I can obtain the easier the descision (**)
The plan is to create the smallest frontal area as possible around the nose to maximise the potential of the Jab, the prop diameter is only 62". The bottom cowl has been sorted but now I need to take about 30mm off the front of the top cowl and taper it back to the firewall. The rest of the airframe is about as "clean" as we are going to get although a fillet at the wing root might be a good idea for better cruise.
I will take some pictures of the build so far, the final colour has still to be painted, at the momnt its all white and looks a little dull. :| :|
Home EVA'S FIELD
AndyG
Postby AndyG » Tue Oct 21, 2008 9:23 am
James Bentley wrote:Hi Rudi
James knowing what a perfectionist you are I doubt it looks dull. Post the pics man ## ##
James Bentley
Postby James Bentley » Tue Oct 21, 2008 9:56 am
Andy, you will have to wait a few days :roll: :roll:
I have not taken any pictures at all of the build (**) (**)
Colour choice at the moment -- teal/turquoise with pale yellow or lime (!!) (!!)
Inspiration comes from seeing a similar combination on a mountain bike made by Ibis, it is absolutely beautiful and so different!!!
Home EVA'S FIELD
Old, Fat and Hairy
Postby Old, Fat and Hairy » Tue Oct 21, 2008 11:26 am
Are the local de Necker props any good?
Postby Tailspin » Tue Oct 21, 2008 11:38 am
Old, Fat and Hairy wrote:Are the local de Necker props any good?
In my Opinion the DeNecker Props are of the best around. !!!! !!!! !!!!
Postby John Boucher » Wed Oct 22, 2008 7:28 am
Pieter de Necker's props are excellent.....
I know he has made a few for the Bantams with great results....
James Bentley
Postby James Bentley » Wed Oct 22, 2008 7:48 am
Thanks for the info on Piet de Necker
Contact details please
Had one of his props on a Thunderbird many years ago and it was excellent vhpy vhpy
Home EVA'S FIELD
Stephan van Tonder
Postby Stephan van Tonder » Thu Oct 23, 2008 11:39 am
Flew a cheetah this morning with 80hp jabi and a sensenich prop. Very nice and smooth and it cruises at around 90-95 mph. It's not hugely quick out of the blocks but not bad either. I didn't look at the size but I'm sure if you contact Rainbow aircraft Vladimir would be able to give you the size. They have sold about 10 planes with that combo.
James Bentley
Postby James Bentley » Thu Oct 23, 2008 11:46 am
As promised Andy, Rudi and others, photos of the Zenair.
Top cowl to be cut down
IMG_0017 [640x480].jpg (50.58 KiB) Viewed 3027 times
Steam guage panel
IMG_0021 [640x480].jpg (90.41 KiB) Viewed 3026 times
Will send more later
James
Engine inatallation
IMG_0022 [640x480].jpg (86.64 KiB) Viewed 3015 times
Home EVA'S FIELD
James Bentley
Postby James Bentley » Thu Oct 23, 2008 11:55 am
Some more pics...
Wings all ready and waiting
IMG_0024 [640x480].jpg (75.54 KiB) Viewed 3005 times
When I am finished I want to look like that!!
IMG_0025 [640x480].jpg (77.02 KiB) Viewed 3005 times
Side view, top cowl too tall!
IMG_0019 [640x480].jpg (59.67 KiB) Viewed 2994 times
Home EVA'S FIELD
